Need your help with these power steering rack ports - FFCars.com : Factory Five Racing Discussion Forum
Old 07-07-2012, 11:04 PM   #1 (permalink)
Hey all, I just started looking in to the fittings I need to plumb my fox power steering setup, and noticed that the top threads of the outlet port on my used rack are a little gacked.
Hard for me to tell since I don't have the outlet fitting yet, but will I be able to get a reasonable seal with that chunk taken out? Is the actual sealing surface the grimy ring surrounding the threads that I have neglected to clean? I can't tell.
big jim is offline   Reply With Quote
Old 07-07-2012, 11:57 PM   #2 (permalink)
ROADRACER83's Avatar
Fitting seal
The fittings on the racks are an O ring that fiis into the groove at the top of the threads. That groove needs to be SUPER clean, and it looks like you have a enough threads left to tighten the fitting down. I'd be looking for the broken threads to make sure they didn't fall into the rack. See the Breeze web site to see AN fittings and the O ring.
Old 07-08-2012, 02:52 AM   #3 (permalink)
Drop Zone's Avatar
Is that a crack between the openings? Looks like 2 of them.
Drop Zone is offline   Reply With Quote
Old 07-08-2012, 06:03 PM   #4 (permalink)
I think your threads are OK and I hope those are just two casting lines that look like cracks.
Old 07-09-2012, 03:22 AM   #5 (permalink)
those are definitely casting marks or dings.
Thanks for easing my mind guys, here's hoping I don't get any leaks when I button it up.
Old 07-09-2012, 04:34 AM   #6 (permalink)
steno's Avatar
I got a great set of hoses from gottashow.com. Fittings were great,o-rings included,and the stainless hoses look sweet! Made the install a dream.
steno is online now   Reply With Quote
Old 07-09-2012, 05:00 AM   #7 (permalink)
JJ'snakepit's Avatar
Try Breeze ... Just over a hundred bucks I did mine hose and all...
Mark 3.1 delivered Oct 08, Massing parts for 331 stroker, GT40 heads, EFI, Ford E-cam, ff5 4 into 4 headers, Explorer Intake. T5 w/ S10 midshift, IRS and ff5 LCA's, Koni coil overs. Power steering, ABS power boosted 13" Cobra Brakes front and Thunderbird rears. 2003 Cobra After markets 18/9's front 18/10.5 rears. Tires 275's front and 315's rear. Cannonball Cobra's Trunk box.
JJ'snakepit is online now   Reply With Quote
