Having trouble fitting the Vert Tunnel Wall - FFCars.com : Factory Five Racing Discussion Forum
Old 07-03-2012, 07:35 AM   #1 (permalink)
Hi everyone,
I've run into a panel fitment problem and I'm not sure what to do. I cannot get the downward arm of the vertical transmission tunnel wall to meet up with the two passenger compartment pieces (one on the side of the tranny tunnel and the other from the foot box). I've tried force it into place, but it won't go and I figure before I get rough I'd check with the experts.
If I look at the vert tunnel panel it's pretty clear that it isn't symmetrical. The passenger side is cut at a different angle than the drivers side. What I can't tell is if it's supposed to be. I'm pretty sure that if it were cut the same shape on both sides it would fit.
I tried to take a picture of the panel, but it didn't come out very good. You can tell that it's already starting to distort as I try to force it into place.
Does anyone know if that panel is supposed to be symmetrical and I have a poorly produced panel? Do I need to try to really bend (which would actually distort) the panel to try to make it fit. Maybe I can hammer it into place, but that doesn't look like it will really work. It looks miscut to me, but I'm not sure.
Any thoughts?
MK4 Base Kit w/ IRS ordered 12/15/2011, received 2/11/2012. Project Honey Badger Build Site http://www.zippyfoo.com
Zippyfoo is offline   Reply With Quote
Old 07-03-2012, 09:21 AM   #2 (permalink)
That panel can be a little tough sometimes. dont be afraid to put the passenger side panel on the outside instead of the inside to get a better fit. You are going to have to make it work or try getting a new one from FFR. remember its all covered with carpet and will never be seen again. I believe all bends in these panels are done by a trained eye. Not machine controlled.
Old 07-03-2012, 10:28 AM   #3 (permalink)
thebicman's Avatar
Trim the panel if the fit will be better for you. If you have a gap, it can always be filled also.
mark III #4165, on the road in white gelcoat.
thebicman is offline   Reply With Quote
Old 07-03-2012, 01:40 PM   #4 (permalink)
Out of Time
HIRISC's Avatar
Bend, cut, grind, adapt, overcome.
As stated above, you'll never see it again and the fitment order there doesn't matter - it will be covered by Dynamat (or equivalent) and carpet.
MK4 #7201
Delivered 3/25/10
Go-Kart 5/28/11
On The Road 6/28/12
HIRISC is offline   Reply With Quote
Old 07-03-2012, 03:22 PM   #5 (permalink)
Plodding Along
CCRsAC's Avatar
+1 on that!!! I bent, cut, and ground the snot out of mine to get it to fit right - in the end, it was a perfect fit and aligned very nicely with the inner panels of the footbox and the sidewalls of the floor/trans-tunnel pieces.
Later,
Chris
Mk3.1 #7074
Picked-up at FFR - 10/10/09
CCRsAC is online now   Reply With Quote
Old 07-03-2012, 03:30 PM   #6 (permalink)
CobraDVM's Avatar
Doug - mine fit like crap as well. I ended up installing a heater console in front of it, so I cut it into 3 pieces - so at those corners where it's starting to distort, I cut it up to the top, so I had 2 long L shaped pieces, and a flat piece. It allowed the side pieces to sit flush rather than forcing them to fit.
Howard
CobraDVM is online now   Reply With Quote
Old 07-03-2012, 05:00 PM   #7 (permalink)
cobrajj's Avatar
On my 3.1 kit it took some addition pursuading to get all the panels to finally come together to line up enough for the drilling and riveting. Adjust as needed. Jim
cobrajj is online now   Reply With Quote
Old 07-04-2012, 03:51 AM   #8 (permalink)
Ok, so it looks like I just need to make it fit.
Thanks for the advice everyone!
Old 07-04-2012, 09:20 AM   #9 (permalink)
Out of Time
HIRISC's Avatar
Yes sir.
MK4 #7201
Delivered 3/25/10
Go-Kart 5/28/11
On The Road 6/28/12
Old 07-04-2012, 02:38 PM   #10 (permalink)
Steak's Avatar
Than goodness for clecos
Chuck
FFR 6624, delivered 05/20/08, Levy Stage 3 (EFI), IRS, 15" PSE GT40 wheels. Whitby paint and finish. Forte's hydraulic clutch activator conversion. Completed and tagged 07/29/2011.
Steak is offline   Reply With Quote
Old 07-05-2012, 10:40 PM   #11 (permalink)
*** CAD Librarian ***
i clearly remember that i had the same problem. i was afraid to trim, bend, and do the under/over thing as suggested.
once everything is covered with fatmat & carpet, you'll never know what underneath.
___
Old 07-05-2012, 11:06 PM   #12 (permalink)
Frank Messina's Avatar
Once you get it as close as you can, that's when you whip out that roll of aluminim foil tape to fudge in the gaps. Makes it look real professional. Then you pile on the insulation and carpet. Bam, just like factory.
Frank
Frank Messina is online now   Reply With Quote
Old 07-07-2012, 02:56 AM   #13 (permalink)
Just an update: Using a hammer, a grinder and a little persuasion is going a long way to making this fit.
Once it gets all sealed up it should look fine.
Thanks for the advice!
