Horn Sound from Engine - FFCars.com : Factory Five Racing Discussion Forum
Old 07-01-2012, 04:12 AM   #1 (permalink)
PKingsley's Avatar
Drove the car about 200 miles today and at the end coming home I noticed a horn sound coming from the engine - only above 1500 rpm or so. Below 1500 it stopped. I took this video with my cell right after pulling in my garage
Sounds like some sort of resonance. I think it's heat related. After the car cooled down it stopped doing it. Anyone had something similar happen? Sounds near the intake but I can't pinpoint it.
Phil
Mk III, 3 Link, 347 EFI, AFR heads, Trick Flow intake, x cam, 3.73 Gears, 42 lb. Injectors, Moates Quarterhorse, Full Width Roll Bar
PKingsley is online now   Reply With Quote
Old 07-01-2012, 04:36 AM   #2 (permalink)
Joe
Senior Mem / Moderator
Joe's Avatar
Check your PCV..
Joe - Texas Cobra Club - DFW
GRADUATION THREAD LINK
BUILD VIDEO!!
Go Cart Video
Old 07-01-2012, 08:24 AM   #3 (permalink)
Master Student
Doug Meldrum's Avatar
I had a similar problem. Mine was a cheap Checker Auto vacuum line from the intake to the PCV collapsing in on itself and creating a vibration. I replaced the hose with a better quality and problem fixed.
FFR #7228, under construction
Doug Meldrum is offline   Reply With Quote
Old 07-01-2012, 01:53 PM   #4 (permalink)
Silverstreak02's Avatar
I had that same noise on my car after it got hot. The hose between the PCV and the carburetor was collapsing and creating a reed type effect. It was very soft and pliable when I touched it. I bought a thicker hose that was specific for the PCV system and the noise went away.
Old 07-01-2012, 02:47 PM   #5 (permalink)
PKingsley's Avatar
Thanks guys. The PCV hose I have on there is pretty thin so I'm sure that's it.
Phil
Old 07-01-2012, 03:52 PM   #6 (permalink)
ROADRACER83's Avatar
Think outside the box
PKingsley:
Poke some holes in it and you can play it like a flute or bagpipes.
Old 07-01-2012, 05:08 PM   #7 (permalink)
I had a bbk throttle body that did that, changed throttle body notice gone
Sparky1 is offline   Reply With Quote
Old 07-01-2012, 07:31 PM   #8 (permalink)
Wade Chamberlain's Avatar
do you have a vent line? I couldn't tell from the vid. You should have a vent line just upstream of the throttle body, that usually connects to a fitting on the oil fill of the passenger valvecover. That's where fresh air normally enters for the PCV system. If you block it off, it'll suck air around front and rear main seals, valve cover gaskets, etc....and make all kinds of crazy noises.
Wade Chamberlain
FFR2229K
Old 07-01-2012, 11:30 PM   #9 (permalink)
PKingsley's Avatar
Yes there's a vent line connecting from the elbow just in front of the throttle body to the oil fill tube. It's underneath not visible in the video. I mistakenly plugged that years ago and got a bunch of high pitched squeaking so I know what you're talking about. I'm pretty sure it's the PCV tube. It's a real thin rubber I can easily pinch closed. Plan to replace this evening.
Phil
