Gas tank assembly question - FFCars.com : Factory Five Racing Discussion Forum
Old 06-27-2012, 01:06 AM   #1 (permalink)
luey2009's Avatar
Im awaiting the delivery of my rear end from FFR, can I install the gas tank portion of the build and then go back to install my rear end later? will there be any issues in me doing this?
FFR #7815 mk4 complete kit ordered 4/23/12, kit completion date 5/26/12,delivered 6/3/12,roller w/lights 9/15/12, motor installed 11/3/12,first start 11/24/12,first go cart 3/30/13
Old 06-27-2012, 01:08 AM   #2 (permalink)
QSL
Stealth Ninja FFR builder
QSL's Avatar
i think it will be just fine. I would move forward.
MK4 delivery 12/17/11
Build thread: HERE
Epic First start video HERE
Build thread: HERE
Old 06-27-2012, 01:20 AM   #3 (permalink)
MK4
Coolest Puzzle ever !
MK4's Avatar
Move on
Move on on issues with installing the rear end after the tank
Mk4
Work Hard, Play Harder !!!
http://www.ffcars.com/forums/17-fact...ompletion.html
MK4 is offline   Reply With Quote
Old 06-27-2012, 01:56 AM   #4 (permalink)
luey2009's Avatar
thanks guys !
Old 06-27-2012, 02:01 AM   #5 (permalink)
Struggling New Guy
NAVYDUDE's Avatar
YEP- go forward- no worries--- let me know if your having trouble with the passenger side tank strap... I used a bottle jack with a screw driver to push the tip of the strap into place- worked awesome...after a solid 2 hours of cursing and swearing the strap didnt fit...
Received 8 JUN 2012
Roller 20 JUL 2012
Go Cart ??
Legal ??,
NAVYDUDE is offline   Reply With Quote
Old 06-27-2012, 02:17 AM   #6 (permalink)
How much clearance between the 3/4 tubing and the filler pipe coming out of the side of the tank. Mine is touching the 3/4 square tube.
FFR 7713, IRS std width, 347, Wilwood 12.8" 6 piston front, Levy-Wilwood 12.2 4 piston rear
My5ive01 is offline   Reply With Quote
Old 06-27-2012, 02:23 AM   #7 (permalink)
MK4
MK4's Avatar
Clearance
Mine just clears it by 1/8 or so.
Mk4
Old 06-27-2012, 03:00 AM   #8 (permalink)
emac's Avatar
I adjusted the filler neck, flattened it a bit, to get clearance.
351 tko 500
Delivered Nov 13, 2011
First start December 31, 2011
First gocart Jan 12 ,2012
Graduation 05/12/201
graduation thread
Old 06-27-2012, 11:35 AM   #9 (permalink)
Thanks. I may see if I can add small spacers on the four spots where the gas tank flange is supposed to touch. Hopefully that doesn't make the straps too hard to put in place.
Old 06-27-2012, 01:11 PM   #10 (permalink)
emac's Avatar
Make sure the spacers are attached some kind of a way, as you will have to drop the tank several times during the build, to get to the bumper bolts. Chasing spacers will be frustrating. I think flattening the filler tube is just easier, as the straps are hard enough to start without spacers (especially the passenger side)....at least on my build.
351 tko 500
graduation thread
Old 06-27-2012, 01:30 PM   #11 (permalink)
MPTech's Avatar
I think installing the rear-end would be easier without the gas tank in the way (I'm assuming you are not talking about IRS).
As to the filler tube clearance, I bought some half-round furniture tips from the Sears Hardware store to insert into the square tubing the tank rests on. I did have to trim them a little bit with a Dremel to get them to fit. This bought me about another 1/8 - 1/4" clearance. I also bought longer strap bolts and secured the bolts to the mount with a sleeve and nut, to make mounting the straps easier (yes they are a struggle).
Also, FYI, the trunk aluminum needs to be on BEFORE mounting the PS strap in the back (ask me how I know!)
Licensed 4/24/13!! Wahoo!
Old 06-27-2012, 01:38 PM   #12 (permalink)
East Coast Speed Machines
Erik W. Treves's Avatar
that's how I did mine
FFR 1879, Blown DSS 306,REDLINE management, VeryCoolParts Tuned 460RWHP, TFS Intake, Heads, Cam, 1.6 RR, 3.08's, 3-link , 315's (SOLD)
FFR 6651, Green Lantern, 408W, Hellion 66mm Turbo, JGS Waste gate / Blowoff valve, Tec-GT management, VeryCoolParts Tuned, 575 RWHP, 689 RWTQ, 3.27's, 3-link , 315's.
Erik W. Treves is offline   Reply With Quote
Old 06-27-2012, 08:55 PM   #13 (permalink)
luey2009's Avatar
cool thanks for the tip!
Old 06-27-2012, 09:10 PM   #14 (permalink)
Bob McLaughlin's Avatar
Personally I would not put the tank in. Assuming the chassie is up on stands or the likes there of, you will need to lift the rear to bolt it in. having the tank in will make getting a hyraulic jack with the rear balanced on it under the chassie more difficult. I had my chassie on dollys. I found it very easy to put the differential on two jack stands and move and position the chassie to the rear. Trying to balance the rear on a hydraulic jack will be a challenge. of course this was for me installing it by myself.
just my opinion and what worked for me.
Bob Mac
Bob McLaughlin is offline   Reply With Quote
Old 06-27-2012, 09:23 PM   #15 (permalink)
Tatika's Avatar
Access plate
Luey2009:
Just a thought - Do the Mk 4's have access panels in the trunk floor for the fuel pump and sender? If not you might consider putting something in now - it makes it so much easier when (not if) you need to do something to either one; rather than having to drop the tank. Boat supply stores have 4, 5, 6" + access covers (round or oval) here is one:
WEST MARINE Screw-in Deck Plate, 6", Black at West Marine
June 07 Build School; FFR #5765 delivered Aug 27/07; Complete May 2009; 347 Levy all forged rotating assembly, Edelbrock E-Street heads, Explorer intake, 70mm TB, BBK 76mm Mass air, 30lb injectors, 255 fuel pump, Gas-N sidepipes, PS with Heidts valve, PB, FF5 heater, Team III wheels & BFG tires ....
Tatika is offline   Reply With Quote
Old 06-28-2012, 09:28 PM   #16 (permalink)
Out of Time
HIRISC's Avatar
Originally Posted by Tatika View Post
Luey2009:
Just a thought - Do the Mk 4's have access panels in the trunk floor for the fuel pump and sender?...Greg
Yes, they do. (did)
MK4 #7201
Delivered 3/25/10
Go-Kart 5/28/11
On The Road 6/28/12
HIRISC is offline   Reply With Quote
Old 06-29-2012, 01:44 AM   #17 (permalink)
luey2009's Avatar
Luey2009:
yes they do, at least mine does
Old 06-29-2012, 01:45 AM   #18 (permalink)
luey2009's Avatar
Bob Mac
hmmm good thought thanks Bob
Old 06-29-2012, 01:54 AM   #19 (permalink)
samadhi's Avatar
I've had to pull my rear out after installing the tank, with wheels on you can roll the rear in place and attach the arms then jack it up.
Piece of cake.
FFR 7502
408w
rhs 200
rpm airgap
750 Speed Demon
Over budget funding provided by my wife's business, the best yoga studio in Ottawa!
First start... check
Go-kart... check
body on drive... waiting on insurance appraisal
samadhi is offline   Reply With Quote
