Need another Temp sensor port - FFCars.com : Factory Five Racing Discussion Forum
Old 06-26-2012, 07:31 PM   #1 (permalink)
Cory L.'s Avatar
I am setting up an auto fan and need an idea where to put another temp sensor. I currently have one in the manifold for my efi, I have one in the 90 deg inlet for my gauge.
I was looking at fortes degas tank. But just wanted to see what others have done. If I went with Forte's I would put the guage temp sensor in the tank and put the auto fan in the 90 deg inlet.
Any ideas or comments are welcome, I currently have a manual switch to control fan.
Could I drill and tap the "T" fitting where the rad cap is?
As always thanks guys
Cory
Complete MK3.1 kit #6800 Picked Up Oct 18, 2008
plugging along, is a snails pace plugging?
Semper Fi
Cory L. is online now   Reply With Quote
Old 06-26-2012, 07:36 PM   #2 (permalink)
I see that you have a 3.1 complete kit which implies an FFR (AFCO) aluminum radiator. Remove the bleed petcock from the upper corner of the driver's side tank and put your sensor there.
I'm a big fan (no pun intended) of the Painless coolant temp switches. They are a true on/off switch, not a grounding switch, so you would simply need to put it in parallel with your current manual toggle. Several temperature ranges are available; here's an example:
http://www.summitracing.com/parts/PRF-30111/
Doesn't get much easier
Mk4 Build thread
Mk4 Bodywork & paint thread
Old 06-26-2012, 07:54 PM   #3 (permalink)
Cory L.'s Avatar
Yes I do have the AFCO Rad.
So I should put the guage sensor in the Rad and put the auto fan one in the 90 deg inlet?
Semper Fi
Old 06-26-2012, 07:56 PM   #4 (permalink)
ROADRACER83's Avatar
Adapter
Jeff has got it right. That is good spot to put a switch if you have room. If not, there are radiator hose inline adapters for a switch also. Check with Forte or Breeze and see if they have them. Jeg's has some from Autometer and FlexaLite.
radiator+hose+adapter+ - JEGS High Performance
Old 06-27-2012, 01:02 PM   #5 (permalink)
narve00's Avatar
Keep the gauge sensor mounted in the manifold, otherwise it will never be accurate. There should be a sensor location at the driver's side front that can be used for a gauge.
The fan sensor can be in the radiator.
narve00 is offline   Reply With Quote
