Lizard Skin? - FFCars.com : Factory Five Racing Discussion Forum
Old 06-22-2012, 03:44 AM   #1 (permalink)
Chuck_Sloggett's Avatar
Lizard Skin?
I am looking for pros and cons of using Lizard Skin Ceramic insulation under the carpet.
How much will I need to do the job and where to buy?
Thanks for any input. -- Chuck
Mark 3.1 in progress, 3 link, Konis, tubular LCA's, Carbed 347, AFR 185's, Comp HR274XE Roller Cam,
Gas'N stainless headers and side pipes, Forte's front sway bar, 3.55 rearend, Hydroboost, SN-95 spindles, 4 wheel disc brakes, Power steering, Classic instruments, Competition style dash, Red w/white stripes, heated seats, heater, etc.
Chuck_Sloggett is offline   Reply With Quote
Old 06-22-2012, 04:32 AM   #2 (permalink)
LuisL's Avatar
You can buy it in eBay, speedway motors or directly from them. This is the route I will be taking also. Two gallons for the cockpit should do it. You will be happy with the results.
FFR4398. Powder coated chassis, pin drive IRS, custom side pipes, custom 289 FIA features, all aluminum 4.6L DOHC with Twin Turbos, Tremec TKOII, and lots of other goodies.
LuisL is offline   Reply With Quote
Old 06-22-2012, 05:19 AM   #3 (permalink)
mongoose7's Avatar
Chuck,
I've been driving mine since 08 with bare aluminum cockpit. No heater. From teens to 90's f.
I've been in other mfg. roadsters and street rods. Road noise and insulation differense is minimal at best. If it makes you happy spend it. I'm running a 302 carbed with ceramic FFR 4 into 4 pipes. Wipe and go interior with no mildew from wet carpet.
M7
mongoose7 is offline   Reply With Quote
Old 06-22-2012, 09:07 AM   #4 (permalink)
I have Lizard Skin in my Mk3 and I'm very happy with it. 2 gallons will be plenty. It works exactly as advertised. I have the standard FFR carpet over it. No heat issues with my warmed up 306. Gives the sound dampening to the .040 panels that I wanted. One of the big advantages is ease of installation. Spray on versus cutting and fitting a bunch of pieces. The only downside I can think of is that some consider it overpriced. There are cheaper alternatives, but there are also more expensive. I like it, and would definitely use it again.
Old 06-22-2012, 05:40 PM   #5 (permalink)
FFR 7469
PhoneGuy's Avatar
This is such a difficult subject for me as there are way to many solutions out there. But this does seem to be one of the easiest or cleaner installs.
How does the stuff smell? Is there any after odor that sticks around after install?
Just when I thought I was going to go with the Koolmat something else pops into my mind...
First Start First Start Video
First Go Cart First Go Cart
Old 06-22-2012, 07:25 PM   #6 (permalink)
Laser Stan's Avatar
sound and/or heat damping?
The lizard skin products seem to either sound or thermal barriers. Are they actually the same thing? Do they have combo products? I you had to choose one or the other, which one would you choose for these cars?
Laser Stan is offline   Reply With Quote
Old 06-22-2012, 08:23 PM   #7 (permalink)
LuisL's Avatar
The ceramic insulation does both things. It is the one to use.
I will also use it under the fenders for rock chips.
Cheers
Old 06-23-2012, 01:35 PM   #8 (permalink)
DMW
DMW's Avatar
I used Lizard Skin on my build. I brushed it on as it was easier than setting up a sprayer, masking, etc. If you ask me, it seems exactly like common dirt suspended in a latex base. For all I know this could be exactly what it is.
I'm not convinced that it does much for the car. The carpets alone will provide a degree of heat and noise insulation and real noise insulation is best done on the bottoms of the floor pans, maybe with bed liner.
Also, the real heat comes from leakage around the dash. By contrast the heat transfer to the aluminum panels seems to be minimal.
DMW is offline   Reply With Quote
Old 06-23-2012, 02:12 PM   #9 (permalink)
Xybram's Avatar
Second skin has a better product. More expensive but you get a nice solid feeling car.
Complete Packages : Factory Five Roadster | Second Skin Audio
hth
Chris
The more I know the more confused I get.
FFR #6607 The Dream Begins
Xybram is offline   Reply With Quote
