Driver's Footbox Top - FFCars.com : Factory Five Racing Discussion Forum
Old 06-20-2012, 08:40 PM   #1 (permalink)
Has anyone come up with a hinged or removable driver's side footbox top? There are a lot of pieced in the top of the driver's footbox that can only be accessed by removing the footbox top which requires removing the body. Does anyone have a design for a removable top so that items like the brake master cylinders can be changed without removing the body?
jimwallace is offline   Reply With Quote
Old 06-20-2012, 08:44 PM   #2 (permalink)
Benched
Mikey_P's Avatar
Jim, there are a lot who have done just that. I'm sure they will post with their versions. Here is what I did with my Mk3 and am making a larger one for my Mk4.
Here is a little closer view.
FFR5546 morphing into FFR7387
Garage Cam
Mikey_P is online now   Reply With Quote
Old 06-20-2012, 09:29 PM   #3 (permalink)
QSL
Stealth Ninja FFR builder
QSL's Avatar
Here is a good thread that shows the basic idea as well.
Footbox Removable Cover
MK4 delivery 12/17/11
Build thread: HERE
Epic First start video HERE
Build thread: HERE
Old 06-21-2012, 03:26 AM   #4 (permalink)
GWL
I've set it up so I can take off the entire top.
First, I cut the forward top leading edge of the footbox down so the inside top cover piece will now fit flush against the inside of the 3/4" tube. I then tapped the 3/4" tube for button head screws. Now, my footboxes are a little different/weird looking than most. I've gone beyond the regular looking footbox. The angled pieces along the different edges of the footbox and held on by button head screws are actually covering two footboxes one inside the other with a layer of Pyrogel insulation in between. The angled pieces simply cover the insulation and give a finished look to the edges of the footbox. The outside footbox and angled pieces are mirrored stainless steel with the protective layer still on. None the less, that entire top piece is removable.
I have mounted my body to check for a proper fit on the footbox and other measurements. I also wanted to check to be sure I could remove the top piece without too much trouble. It is easy to remove with the body on. Also note the edge of the hood opening is able to fit down over the 3/4" tube without touching the aluminum top piece. Most will trim that edge of the fiberglass so it will not touch the aluminum and fully sit down onto the 3/4" tube.
George
'52 MGTD - Sold
'62 MGA - Sold
