Gas tank breather? - FFCars.com : Factory Five Racing Discussion Forum
Old 05-15-2012, 01:14 AM   #1 (permalink)
Eldrik's Avatar
Gas tank breather?
What kind of rubber grommet are you guyz using on your custom gas tank vent tubes? ARROW
I bought some 1 1/4 inch valve cover grommet, but it was a lil' small.
I think my Mustang tank has about a 1 7/16 - 1 3/8 inch hole.
I just wanna run a standard 5/16 fuel line up the fill tube with a small charcoal filter at the end. Would a PVC valve on the tank end be a good idea?
Any ideas or part #s?
And another curiosity: What is this tab on the back of my Mk 3.1 chassis? ARROW
Is that for the trunk prop rod?
Thanx!
Eldrik is online now   Reply With Quote
Old 05-15-2012, 01:24 AM   #2 (permalink)
You should use the proper grommet for the fuel tank so as to be fuel resistant. Check Breeze.
That bracket is used with 94 and later fuel tanks. Should explained in the MANUAL.
Old 05-15-2012, 10:25 AM   #3 (permalink)
Benched
Mikey_P's Avatar
Since I didn't need that tab to mount my tank I just cut it off.
I think I have the grommet and the vent for the tank that I will not be using. I will check when I get back from radiation therapy this morning and let you know. If I do you can have it. PM me your address.
FFR5546 morphing into FFR7387
Garage Cam
Mikey_P is offline   Reply With Quote
Old 05-15-2012, 01:50 PM   #4 (permalink)
Howff's Avatar
Breeze sells real nice vent
Howff is online now   Reply With Quote
Old 05-15-2012, 03:22 PM   #5 (permalink)
Silverstreak02's Avatar
When am I going to get to see your car? Are you getting close?
Old 05-15-2012, 03:34 PM   #6 (permalink)
TC COBRA
TAnderson's Avatar
The stock vapor vent check valve has a check ball that prevents fuel from leaking due to overfilling, slosh, or rollover.
Koni's, Ford Racing 306, air-gap, Holley 600, Mallory Maxfire, 327 grears, big 15 inch meats.
TAnderson is offline   Reply With Quote
Old 05-15-2012, 04:59 PM   #7 (permalink)
I used the stock vapor valve that came with my complete kit. It fit and works fine. I don't have any problems filling the tank due to the size of the valve. I imagine you can get it from Factory Five or maybe even NAPA.
Old 05-15-2012, 10:59 PM   #8 (permalink)
Eldrik's Avatar
Thanx guyz!
*PMs sent*
Old 05-16-2012, 02:38 PM   #9 (permalink)
Benched
Mikey_P's Avatar
Here is a pic of what I have.
Garage Cam
Old 05-16-2012, 08:58 PM   #10 (permalink)
Just Pluggin Along
lilnuke's Avatar
I used Breeze big bore vent with a small PVC charcoal filter at the end.
Check valve grommet/seal: Breeze Automotive Factory Five Racing
MKII FFR4525 - $old
MKIII FFR7032 - Work in progress...
lilnuke is offline   Reply With Quote
Old 05-21-2012, 11:02 PM   #11 (permalink)
Eldrik's Avatar
Welp, I found a use for that lil' tab (ARROW) on the back...
