Flexible exhaust insert - Page 2 - FFCars.com : Factory Five Racing Discussion Forum
Old 06-07-2012, 10:33 PM   #31 (permalink)
cobrajj's Avatar
FFR4FUN, Are the round phillips heads shown securing the insert tube to the SS flex tubing, sheet metal screws or bolts going completely thru the insert and nutted on the other side? Jim
cobrajj is offline   Reply With Quote
Old 06-07-2012, 10:44 PM   #32 (permalink)
Hey Jim, the fasteners are 8-32 or 10-32 phillips hd screws with a nut on the other side. I used nyloc nuts but the nylon melted (but still held), I'd use either blue loctite or double nut. I've been running the inserts for the past several days and I really like them, no rattles at this point, nice mellow rumble.
FFR4FUN is offline   Reply With Quote
Old 06-09-2012, 12:01 AM   #33 (permalink)
dajomaco's Avatar
Interested
Larry, Jim, Very interested in this ...Jim keep us posted on your progress ..Pics Thx Darc
dajomaco is offline   Reply With Quote
Old 06-15-2012, 02:06 PM   #34 (permalink)
Great idea!
BRM #09 - 5.0/30 over. Victor Jr. intake & heads, 70mm TB, 1.6 rollers, sweet cam, 3:55 rear w/ discs.
On the road!
PUDDY is online now   Reply With Quote
Old 06-15-2012, 03:23 PM   #35 (permalink)
cobrajj's Avatar
I've been slowly working on quieting my sidepipes using FFR4FUN's auger insert design. Have the first one completed and the other one will be easier now that I have a pattern to duplicate. Once installed, I'll report on the results. Jim
Old 06-15-2012, 08:39 PM   #36 (permalink)
Jim, great pics . . . keep 'em comin' . . . really hope your inserts work as well as mine have been. Larry
Old 06-15-2012, 08:43 PM   #37 (permalink)
cobrajj's Avatar
Larry, Thanks for your idea and photos. They've been a big help. Jim
Old 06-24-2012, 01:20 AM   #38 (permalink)
cobrajj's Avatar
Finished my flexible exhaust auger mod for the FFR sidepipes. Followed FFR4FUN and it worked out great. Started up in the garage without earplugs, noticable reduced noise level and no more annoying high pitched bark. Only drove around the block, but I expect it to also be much less irritating on the freeway. Jim
Old 06-24-2012, 03:08 AM   #39 (permalink)
Hey Jim, so glad that all is going well with the exhaust inserts. If you can, please shoot a couple of pics of the whole side pipe, maybe a couple of angles. The inserts do indeed cut down on the noise level on the freeway. However, the road noise is still pretty tough. My next design effort will be a wind screen that sits behind the seats and maybe attaches to the roll bars. I had a BMW 3 series rag top with a windschutz (German spelling) and it made a real difference in lowering high speed road noise.
Old 06-24-2012, 03:05 PM   #40 (permalink)
dajomaco's Avatar
Hi Jim, Did you have any issues with the first 2 augers going into the smaller part of the side pipe....did they slide in OK or did you kinda have to screw them in ? Thx Darc
Old 06-24-2012, 04:04 PM   #41 (permalink)
cobrajj's Avatar
I cut off 5/16" off of the first two augers, then grinding and trial fitting them, until they would screw into the louvered tube. Used a extra long needle nose pliers to turn the eyebolt, until it stopped, lined up and drilled to allow a 5/16" bolt to be inserted in from the back of the sidepipe(about 45 degree angle). Can't be seen unless you're under the car. Jim
Old 06-24-2012, 10:35 PM   #42 (permalink)
cobrajj's Avatar
FFR4FUN, Here's some photos of the sidepipes you requested. Jim
Old 06-25-2012, 12:04 AM   #43 (permalink)
dajomaco's Avatar
Heres is my inserts...I JB welded in between the pipe and the ss flex hose ...will install in the next couple of days ......I measured the sound level at 101 dbs, we have a city bylaw here now that 96 is the limit ...I hope this works ........Darc
Old 06-25-2012, 01:12 AM   #44 (permalink)
Silverstreak02's Avatar
I'm interested is what you come up with for the windscreen. The noise from the pipes don't bother me as much as the wind at 70mph. If you need help posting pictures of that just let me know.
Old 06-25-2012, 01:48 PM   #45 (permalink)
MikeKelly's Avatar
I'm pretty sure the JB weld isn't going to last long in the sidepipes. What were you trying to accomplish there?
It looks like you've got the inserts bolted to the flex pipe so you should be Ok.
We're only using 2 per side (with no flex) and we're under 95db @ 6K rpm in second measured from 50'.
You should easily stay under 96.
MikeKelly is online now   Reply With Quote
Old 06-25-2012, 05:08 PM   #46 (permalink)
emac's Avatar
I saved and read a bunch of old posts on this topic. I read about some folks having success installing the car chemistry silencers into the J pipes, I also read that some noticed significant HP reduction.
I am wondering if the augers would do better in the J pipes? They seem less restrictive. I assume the folks installing the augers in the side pipes dont have j pipes or need something that is easily removed for track day. Any thoughts on putting augers in j pipes?
ernest
351 tko 500
Delivered Nov 13, 2011
First start December 31, 2011
First gocart Jan 12 ,2012
Graduation 05/12/201
graduation thread
emac is online now   Reply With Quote
Old 06-26-2012, 12:08 AM   #47 (permalink)
dajomaco's Avatar
Mike, I was just trying to eliminate any possible rattles by putting in the jb weld ...if it doesn't hold i know that the scews are double nutted and should hold from the vibration .........I will install the next couple of days and let you know what the new sound level is ...I sure hope your right ............Darc
Old 06-26-2012, 01:25 AM   #48 (permalink)
Jim, thanks for the additional pics, everything looks great. I like the sizzle protectors.
Jeff, I appreciate the interest in the windscreen, it'll be a couple of weeks before I can try some of my ideas. Starting to install new carpeting in the next few days, I'll keep in touch.
Darc, the inserts look good. I'm not sure about the JB weld, let us know how/if it works. I thought about using Hi-temp RTV to fill the space between flex tube OD and insert tube ID.
Old 06-26-2012, 01:35 AM   #49 (permalink)
dajomaco's Avatar
FFR4FUN, Thx on the inserts.....I will let you know how the JB weld works out .......The high temp silicone i think would have been a better idea, i guess wait n see....... should be inserting them on Wed of this week .......will post after that .......Darc Thx again to this thread for all the help ...much appreciated ....Darc
Old 06-26-2012, 02:09 AM   #50 (permalink)
Hi Ernest, my FFR has j-pipes, several reasons for the flex inserts, they actually reduce noise, cost effective, easy to make and install on already installed side pipes, easily removed for race day . . . I'm really not convinced about any significant power loss on my set up . . . need hard data from a dyno. If you try the inserts in the j-pipes let us know how it works. Larry
Old 06-26-2012, 11:53 AM   #51 (permalink)
MikeKelly's Avatar
It can't hurt - worst case it burns away.
Old 06-27-2012, 06:48 PM   #52 (permalink)
dajomaco's Avatar
Well....I just finished my inserts and what a difference, Like Jim commented before...the bark is gone and in its place is a deeper throatier sound coming out of the pipes.....the 347 sounds awesome......off for some sound testing this afternoon ........Darc
Old 07-02-2012, 05:24 PM   #53 (permalink)
dajomaco's Avatar
Here is a quick video shot this morning with the auger inserts in ......Darc
Old 07-03-2012, 02:10 AM   #54 (permalink)
Hey Darc, Really nice ride with a great sound . . . thanks for sharing . . . have a Great 4th!! Larry
Old 07-03-2012, 04:09 AM   #55 (permalink)
cobracruz's Avatar
The Italian,
Can you give details/pics of the turnbuckle?
Originally Posted by The Italian View Post
I did a similar mod but i used a small turnbuckle to hold it in.
pushing on both ends of the pipe
That way I did not have to drill holes in the pipes
cobracruz is offline   Reply With Quote
Old 01-03-2013, 10:38 PM   #56 (permalink)
Joe.S's Avatar
Cobra sound - YouTube
That sounds really nice. nice lower tone from the pipes.
Joe.S is online now   Reply With Quote
Old 01-04-2013, 04:39 AM   #57 (permalink)
New
SeanHM's Avatar
One word:Brilliant. Thanks for sharing and for adding to the to-do list.
Darc- I'm not usually much for red, but your car is gorgeous. Very clean and simple, like they should be.
SeanHM is offline   Reply With Quote
Old 01-04-2013, 11:31 AM   #58 (permalink)
dajomaco's Avatar
Hey Sean, Thankyou on the car ....The car has since been painted blue as this video was shot while the car was still in jel coat ...Darc
Old 01-04-2013, 01:44 PM   #59 (permalink)
New
SeanHM's Avatar
Oh that's funny. You know I watched the video like 3 times looking for the seams because it it seemed like it might have been. I was on my phone though. Guess I'm weird because I kinda prefer a not so deep gloss on these cars and that it what it looked like. I think it let's the shape speak for itself without the clutter of too much reflection. That said, I'm probably doing blue too . And flexible inserts...
Old 01-04-2013, 01:55 PM   #60 (permalink)
Cheapsnake's Avatar
FFR4FUN, you still here? You mentioned last year you'd be experimenting with a back windscreen. Just wondering if you fabbed one up and how it worked. And thanks for the flexible insert design, my winter project.
Tom
Cheapsnake is online now   Reply With Quote
