old style vs new style lower contol arms?? - FFCars.com : Factory Five Racing Discussion Forum
Old 05-08-2012, 11:56 PM   #1 (permalink)
HookedonFord's Avatar
Post old style vs new style lower contol arms??
A forum member is selling a pair of old style tubular lower control arms.
What is the difference between old vs new style?
I am currently running the fox controls arms with 15" team III's and pro shocks on MKII. Thinking about Koni's, SN95 spindles, and I would like go to 17" wheels in the future.
Thxs in advance, Jim
FFR3235
HookedonFord is offline   Reply With Quote
Old 05-09-2012, 10:01 AM   #2 (permalink)
Sanford's Avatar
The old style may need to be modded for the Koni's. Double check that.
Sanford is online now   Reply With Quote
Old 05-09-2012, 10:41 AM   #3 (permalink)
MJN
MJN's Avatar
Yep, the old style will need modifying to work with the Konis. Not a big deal if you have a welder, I did mine a couple of years back.
Mike....
Old 05-09-2012, 12:12 PM   #4 (permalink)
here is a pic of the two w/ the old style on the left
Click to enlarge.
There is better clearance for the bottom eye of the coilover on the new style.
Old 05-09-2012, 09:30 PM   #5 (permalink)
Thanks for all the info. I would think the shock mount hole is in the same place but the bar interferes? Anybody have a picture of the modified version?
FFR3235
Old 05-09-2012, 09:59 PM   #6 (permalink)
You are exactly right.
Old 10-10-2012, 07:10 PM   #7 (permalink)
johnnybgoode's Avatar
What shocks will fit a MKII?
I have the old style FFR MKII front LCAs with Pro Shocks. My LCA's have been modified with heim joints so I don't really want to replace them. I'm thinking about new shocks as a winter project and was wondering what people recommend and what mods I may need to do to make them fit. Thx Scott
FFR #3870 MK II, Spectra Blue/Arctic White, 1974 351W, 9.75/1, Performer RPM 2.02 heads & intake, QFT SS-650, Comp 442, Crane roller top end, Canton pan, BBK headers, Lobak and CC inserts, Crane ignition, HD T5, 3.55 gears, 3 link, Tubular LCA's, Heim joints & VPM F/R bars, Power steering with Hiedts valve, Power brakes, Fortes bump steer kit, 5 bolt axels, SSBC rear brakes, Oil cooler, Pusher fans, Hlibrant Cobra III's with Nitto 555 275/245/17
johnnybgoode is offline   Reply With Quote
Old 10-10-2012, 11:33 PM   #8 (permalink)
Frank Messina's Avatar
Nothing against Koni but FFR could have stuck with Pro Shocks and saved everybody a lot of grief. Send your shocks to Pro Shocks and have them rebuilt if you think there's something wrong with them. About $60 each.
Frank
Old 10-11-2012, 04:32 AM   #9 (permalink)
Tool Collector
frankeeski's Avatar
Frank
Great advise Frank.
Frank
frankeeski is offline   Reply With Quote
Old 10-11-2012, 11:11 AM   #10 (permalink)
Bill_VA's Avatar
Just so you know, there's more different in the two styles than just the spring mount. The sleeves and bushings on the newer arms are improved. They have a bit longer steel sleeves so that when you tighten the mounts, you're actually tightening against the sleeves and not the bushings. Also the bushings have longitudinal grooves to allow the grease to flow between the bushing and sleeve better.
Bill_VA is offline   Reply With Quote
Old 10-11-2012, 11:52 AM   #11 (permalink)
If the newer style arms are more improved than the older style, and the pro shocks are better, can the older pro shocks fit the newer arms without a lot of trouble?
snakelake is offline   Reply With Quote
Old 10-11-2012, 12:22 PM   #12 (permalink)
MJN
MJN's Avatar
Pro Shocks are a bolt in on the later arms. The geometry is the same between the early and late arms it's just that the later model arms have extra clearance for shocks where the spring seat (cup) is closer to the shock bolt.
Mike....
