Conversion cable to hydraulic clutch ? - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 10 (permalink) Old 04-29-2012, 02:42 PM Thread Starter
neilmathieu's Avatar
What are your suggestions for change cable clutch system to hydraulic ?
I have too much pressure on the pedal and in traffic it is horrible.
I have a 351W stroked 427 with a 10.5 clutch coupled with a Tremec TKO 600, 5 speed.
My parts come from Engine Factory.
I would appreciate web link and/or pictures to make the conversion if you can.
The cost is not important, I want the best and keep it simple.
I will be at the FFR open house next June 9th, hope see you !
a Quebec-Canadian driver from Saint-Georges-Beauce
FFR Mk4 complete kit with no used parts
351w stroker 427 (538hp),
some pictures
neilmathieu is offline
post #2 of 10 (permalink) Old 04-29-2012, 02:50 PM
Make it easy on yourself.
Forte's has a nice hydraulic clutch setup that should work perfectly for you. Has everything you need. (ask for at least a 1" m/c though).
Lots of guys here run it and love it.
dallas_ is offline
post #3 of 10 (permalink) Old 04-29-2012, 03:50 PM
4.6 SOHC T3650 Telorvek
d42davis's Avatar
I just changed a complete kit cable to hydraulic and it is at least a 100% improvement. Pedal pressure is a little less and pedal travel to clutch dis-engagement has gone from 90+% of travel to about 40% of travel.
A 1-1/8: master was recommended and is a direct bolt in with the Wilwood pedal assembly. Slave selection and mounting hardware is dependent on engine/trans, and I have no experience with your set-up so calling Mike is a good idea.
d42davis is offline
post #4 of 10 (permalink) Old 04-29-2012, 10:53 PM
Put a cluch fork extender on it , big improvement , fortes has em,I made my own
BostonBuster is offline
post #5 of 10 (permalink) Old 04-30-2012, 02:39 AM
Chepsk8's Avatar
Made my own hydraulic system that uses the FOX pedals. 7 years, not one problem, racing all seasons.
Another offender is the clutch choice. How heavy a pressure plate?
Chepsk8 is offline
post #6 of 10 (permalink) Old 04-30-2012, 03:31 AM
JJ'snakepit's Avatar
Are you using and OEM cable?
I have heard there is a world of difference in the OEM Cable vs an aftermarket. It has something to do with a Teflon lining..
Mark 3.1 delivered Oct 08, Massing parts for 331 stroker, GT40 heads, EFI, Ford E-cam, ff5 4 into 4 headers, Explorer Intake. T5 w/ S10 midshift, IRS and ff5 LCA's, Koni coil overs. Power steering, ABS power boosted 13" Cobra Brakes front and Thunderbird rears. 2003 Cobra After markets 18/9's front 18/10.5 rears. Tires 275's front and 315's rear. Cannonball Cobra's Trunk box.
JJ'snakepit is offline
post #7 of 10 (permalink) Old 04-30-2012, 04:34 AM
Can you find the link to how you did that? thanks
rich grsc is offline
post #8 of 10 (permalink) Old 04-30-2012, 06:57 AM
SJDave's Avatar
Get at least a 1" MC or 1 1/8", that way you can lower the clutch pedal to be more in line with your brake pedal but push enough fluid volume to fully disengage the clutch. After having a leaky Wilwood Master I went with a Tilton 76 series, they are about $40 more but the quality difference is worth it, the bore is polished and hard anodized...Wilwoods are as cast and NOT anodized. These things are so difficult to replace on a completed car (about 4 hours), that I would spring for the higher quality part for the MC.
I did buy the kit from Fortes, nice brackets and fittings, some shimming of the bracket required depending on your clutch configuration, but easy to do.
Here's a couple pics of my setup on a TKO 500 w Quicktime Bellhousing to a small block.
Hose from MC to Slave:
Slave mounted to Tranny/Bellhousing bolts.
Adapter bolted to Clutch Fork:
SJDave is offline
post #9 of 10 (permalink) Old 04-30-2012, 02:23 PM
J Persons's Avatar
I built my own using a Wilwood slave and a piece of angle iron that is bolted to the Energy Suspension motor mount. I also welded a tab to the chassis so I could run hard line down to the clutch area and attach the flex line with a AN bulkhead fitting. I used a 1" master cylinder, it feels just about the same as a stock Mustang clutch, only much smoother.
Here's a photo of the hard lines and the tab for the bulkhead fitting.
J Persons is offline
post #10 of 10 (permalink) Old 04-30-2012, 03:15 PM
Out of Time
HIRISC's Avatar
I did what Dave and others have done. Buy Forte's kit and stipulate a 1" or 1 1/8" master.
I have the latter.. works perfectly.
I have a new/unused 1" Tilton master lying around. I was going to go with that, but leap-frogged it for a 1 1/8" Wilwood (no leaks here).
MK4 #7201
Delivered 3/25/10
HIRISC is offline
