Need carpet / heel pad advice - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 8 (permalink) Old 02-28-2012, 02:30 AM Thread Starter
cwrandolph's Avatar
Getting close to installing my carpet and thinking about the location of heel pads. I stole this picture from the forum (sorry NuBlue). Definitely want a (smaller) pad beside the go pedal and on the lower part of the floor as shown. Also thinking about a strip near the edge as outlined in red. Is this a high wear area? It's been a while since my car was on the road and I can't remember if I sometimes rested my foot there.
Also, any advice on gluing the pads on? I have this vision of coating the bottom of the pad with adhesive and clamping it between 2 boards as the glue squirts out on my new carpet. How do you do it?
Chas Randolph Sidney, Ohio FFR 6113, '91 5.0 EFI, TFS heads, Comp cam, GT40 Tubular intake, 24lb injectors T5Z w/midshift, 3-link, SAI Mod, TurboCoupe rear 3:55's, 17" Team III's, Picked up @ FFR on 5/5/07, First start 10/5/08, Go Cart 9/27/09, Licensed & Legal 9/30/10. Painted 6/3/12. Graduation 8/21/12. Engine rebuilt & pumped up May '13.
cwrandolph is offline
post #2 of 8 (permalink) Old 02-28-2012, 03:23 PM
Definitely keep the pad along the accelerator that size. There is a lot of back and forth movement with your foot. I bought the 6 1/4" x 13" size for the side.
Got mine here at Miami Corp: Miami Corp: distributor of trim products to the auto, marine and upholstery trades.
The upper footbox level doesn't get rubbed.
HTH.
JGPierce is offline
post #3 of 8 (permalink) Old 02-28-2012, 04:22 PM
MPTech's Avatar
Does anyone put a heel pad on the dead pedal side? (Is the wear minimal / not worth the effort?)
MPTech is online now
post #4 of 8 (permalink) Old 02-28-2012, 10:20 PM
Ray
Ray's Avatar
Send a message via Yahoo to Ray
I just did this:
Ray
Ray is online now
post #5 of 8 (permalink) Old 02-29-2012, 01:47 AM
Silverstreak02's Avatar
This is what I used. A local upholstery shop sewed them in for me. I don't think I would try glue.
Silverstreak02 is offline
post #6 of 8 (permalink) Old 02-29-2012, 03:10 AM
Lay posi
wibby's Avatar
HTH.
Thanks for the link John. I'm just about to start that part of the my carpet. I was wondering where to buy those.
Wibby
306, AFR 185 heads, Kenne Bell Supercharged, power steering, power brakes
wibby is offline
post #7 of 8 (permalink) Old 03-01-2012, 04:18 AM
DMW
DMW's Avatar
Send a message via AIM to DMW
One real problem that I had in the footbox was that my heel wore out floor mats pretty quickly. I attribute that to the soft aluminum floor. I now use aluminum diamond plate as above, but I painted mine with bedliner.
Anyway, you might want to think about some stiffener under the carpet. I think it could make your carpet last longer. Also, you might want to buy a couple spare pads. If my record is representative, you'll need them.
DMW is offline
post #8 of 8 (permalink) Old 03-01-2012, 03:22 PM
AC Bill's Avatar
That was actually the first place I noticed some carpet wear. I added a rub strip along the bottom of the footbox extension mod. That is where the side of my shoe rests, as the upper toe part sits on my dead pedal. Added a throttle pedal rub strip too.
The optional FFR floor mats fit and wear extremely well. They protect the original carpeting. They also protect the area that is highlighted in red, although that area has not yet shown any signs of excessive wear.
I also added some Dynamat under the foot box carpet, to cushion it, as well as act as a sound deadener.
AC Bill is offline
