Help! Axles are still too short... - Page 3 - FFCars.com : Factory Five Racing Discussion Forum
Old 04-28-2012, 02:48 AM   #61 (permalink)
Baghdad Bob
mcwho's Avatar
OK, the shoulder on the stub shaft then is in lieu of the heavier c-clip to keep the shafts from going to deep into the pumkin?
Is the smaller wire c-clip supposed to be on the outside end groove to hold the stub shafts from popping out of the bearings?
a picture would be worth a thousand words.
Ordered MKIII Feb 26 2009
Converted to MKIV Order March 2010 (worked overseas for 4 years)
setup for 302, Complete IRS
Halibrand 15" Wheels
BFG Radial TA Tires
Build School July 2010
Recieved Kit July 2010, #7287
Adds
Power Steering Rack & Offset Alum Bushings - Breeze
Power Brakes - Whitby
Hydralic Clutch & Hydralic Brake Master Cyl. -Modern Driveline
Trunk Battery Box -FFmetal
Firewall Forward -FFmetal
Heater ?
As of April 2012...
Have Florida Title
Have Florida Tags "FF COBRA"
Rear IRS is in as well as rear Brakes
Front Suspension is in as well as Powered Steering Rack
mcwho is offline   Reply With Quote
Old 04-28-2012, 02:59 AM   #62 (permalink)
We know what you're up to
Don Payne's Avatar
Originally Posted by mcwho View Post
My "complete IRS package" that came with this option on my MKIII order that was upgraded to MKIV, had the CV axles delivered completely assembled, there was one wire type type c-clip on the end of the stub shaft that goes into the pumpkin.
I have worried about this since i put it together as the instructions are vague.
Is there there supposed to be the wire c-clip and the heavier c-clip on the end of the stub shaft that goes into the pumpkin ? i am not on the street as yet.
The way the clips are on the axles from FFR as assembled are correct. Just poke it in the pumpkin and you should be good to go.
-Don
Old 04-28-2012, 03:17 AM   #63 (permalink)
Originally Posted by Doug Meldrum View Post
If you have a shoulder on the shaft you will be fine, You should have one or the other ends on don's post #41.
Not so. The shaft that fits into the differential does not have a shoulder or a second c-clip. It will have only one clip on the end, it goes into the differential till the hub is almost against the housing. It should click into place.
Old 09-06-2012, 08:33 AM   #64 (permalink)
Cobra79's Avatar
Don, good info! Can you confirm this is the same problem (short axles) that FFR sent out, and everyone received, the recent spacer fix for?
Current Stage
Kit ordered 1/25/12. Build school 2/10/12. Kit delivered 3/12/12!
The Plan
MK 4, '99 SVT DOHC donor, IRS, dark red w/ stripes.
Project starts
Fall 2011
Cobra79 is offline   Reply With Quote
Old 09-08-2012, 03:46 PM   #65 (permalink)
Fred Yarema's Avatar
Just checked mine...
Didn't bother to take the boots off - can deffinatly feel the lobes through the boot - about 1/4" inside of the cup (in the sprung position). My track width measured exactly to the 58 7/8" (standard width) as specified (sh*t luck!), which is great as I did not want to screw up the alignment. For the record, mine is number 7449, kit picked up in February 2011 and came with the pre-assembled half shafts. The half shafts were back ordered and didn't arrive until around April.
Fred Yarema is offline   Reply With Quote
Old 09-08-2012, 09:47 PM   #66 (permalink)
Don Payne's Avatar
My issue had more to do with my differential being off center. That said, the half shafts (bare) measured 15.5". There were a lot of variables that added to my situation, not the least of which was axle length. In the end I ordered longer axles from DriveShaftShop. They are excellent to work with. I highly recommend them if you need longer axles.
-Don
