STUMPED: Mark 4 exhaust problem - Page 5 - FFCars.com : Factory Five Racing Discussion Forum
Old 10-18-2012, 12:59 AM   #121 (permalink)
Really Wierd. Mine met there measurements as well. Would really like to get to the bottom of what's causing this.
Old 10-18-2012, 11:38 AM   #122 (permalink)
Wade Chamberlain's Avatar
Originally Posted by Sn8keman View Post
So after some back and forth with FFR, they are unable to help me with the header issue because my headers are to spec
LMAO...all they did was take another pair off the shelf and confirm those are F'd up too.
It amazes me that after all these years they can't provide headers that fit consistently. I had one of the first sets of FFR 4x4 headers (made in-house, I think...12 years ago) with spliced together bends/tubes, and even back then, they had the SAME problems. Including the in-house ones, what are they on...they're 3rd or 4th header vendor? Obviously, there will be little nuances between cars that may require some tweaking...1/4"? 1/2" maybe? Not inches.
Wade Chamberlain
FFR2229K
Old 10-18-2012, 01:43 PM   #123 (permalink)
Originally Posted by Gopher View Post
This is what the adjustable setup looks like. With all the adjustability built into this you can see how you can over come your problems. Stainless headers has the solution to all the side pipe nightmares.
What's the cost?
Zaphod is offline   Reply With Quote
Old 10-18-2012, 03:28 PM   #124 (permalink)
evvander11's Avatar
I had the same problem here, and had the same conversation with Factory Five. Below I will attach photos of how I resolved it. Now this may not be the way for everyone to do it, and it has some out-of-pocket expense and does not excuse F5 from the issue. But hopefully it can help at least someone...
We took the header and cut a slot in the bottom side of each pipe right below the flange that mates up with the head. The flange was then bent to give us the proper angle to make the sidepipe flange exit the body at the correct height. Each pipe was then tack welded to hold its place. The rest of the slot was TIG welded (the tack weld held the pipes in the proper place since TIG welding can shrink a bit more).
To finish we sent the header out to get re-ceramic coated and now it fits like a charm! For me it was approximately a $300 fix...but it works and now I can move on with the build.
After a new ceramic coating:
-Brent
Kit Delivered & Build Started: 11-6-10
First Start: 5-26-12
MK IV #7369, 3-Link, 4 Disc Brakes, 17" Bullitts, Kuhmo Ecsta XS 245x45 & 315x35, 3.55 Posi, AOD w/ Lentech street terminator valve body, 5.0 EFI, E-Cam, Explorer Intake, GT40p Heads w/ 1.6 Roller Rockers, 4x4 Headers.
"The biggest helping hand is the one attached to your own freaking arm." -ETriggs
evvander11 is offline   Reply With Quote
Old 10-18-2012, 03:31 PM   #125 (permalink)
evvander11's Avatar
BEFORE ADJUSTMENT:
AFTER ADJUSTMENT:
-Brent
Old 10-18-2012, 03:47 PM   #126 (permalink)
great job on that. Sucks that you had to do that but at some point you just have to give up and find an answer yourself.
Old 10-18-2012, 03:55 PM   #127 (permalink)
evvander11's Avatar
Exactly. It was to the point that nothing was getting done on the build and was getting frustrating.
-Brent
Old 10-18-2012, 04:02 PM   #128 (permalink)
Any idea how many degrees you moved it? Looking at your pictures, I would guess about 4 degrees.
Old 10-18-2012, 05:05 PM   #129 (permalink)
evvander11's Avatar
No I don't have that info, but I would guess about 4-5 like you said.
-Brent
Old 10-18-2012, 06:08 PM   #130 (permalink)
Frank Messina's Avatar
Has anybody ever tried buying a kit with a header/sidepipe credit instead of struggling with this stuff? (I'm being diplomatic) I'm just wondering if FFR would even entertain such a notion but it would be worth a try. I've always said that fitting the exhaust was one of the more labor intensive parts of the build but this is rediculous. I'm a little disappointed that the Stainless headers aren't nice continuous mandrel bent tubes but at least they fit and the price is not bad. I think that trumps looks okay, priced right but don't fit.
Frank
Old 10-19-2012, 02:03 AM   #131 (permalink)
Gopher's Avatar
[QUOTE=Zaphod;2726868]What's the cost?[/QU
About 600.00 in mild steel There website has the costs on it. Stainless Headers Mfg., Inc. fabricates custom headers in stainless and mild steel
Anniverary Edition,Dart Aluminum 427, TKO 600, ISIS, Bump steer,5 link,,Billet upper,lower control arms ,Wilwood six piston brakes front four piston brakes rear,Russ Thompson's turn signal and throttle pedal,Stainless Steele's 427 headers,Fast Freddies Steering.
http://www.ffcars.com/forums/members...s/28242-gopher HTTP://photobucket.com/annivesary-car
Gopher is offline   Reply With Quote
Old 10-22-2012, 02:59 PM   #132 (permalink)
[quote=Gopher;2727175]
I think you mean about $1,600. Add $300 for stainless.
Bart Carter
FFR 4001
Bart Carter is offline   Reply With Quote
Old 10-22-2012, 03:21 PM   #133 (permalink)
ClemsonS197's Avatar
If they are going to sell more than one, you wont be paying $1,600. Give Chris a call. They are a top notch group up there in North Dakota and a pleasure to work with.
MK3.1 - Under Construction
Coyote 5.0
Tremec 3650
Old 10-22-2012, 08:22 PM   #134 (permalink)
WOW! That would be an exceptional price.
Looks like there should be a group buy on something like this.
Bart Carter
FFR 4001
Old 10-22-2012, 10:11 PM   #135 (permalink)
The group buy should be a real small group-like a group of one-maybe Factory Five!
Old 01-13-2013, 09:51 PM   #136 (permalink)
SIZE-O's Avatar
After seeing what evvander11 did by cutting a slot just shy of the header flange and bending it back to suit to revised angle, which is brilliant by the way, solved an obvious design issue.
Its interesting that the driver side header (for 351 engines) has to have a 13 downward bend in the header tubes but not on the passenger side. I know the engine sits off to one side slightly but the angles don't change.
I have monkeyed around with my headers enough now that I have a solution that I am very pleased with aside from going with custom headers. I have posted a couple of times within this thread with what I have been doing. I did cut my headers back effectively removing the 13 degree bend in the tubes. Now they are straight. I made a section of tubes that fit between the header and side pipe.
I have also decided to not continue using my Gas-N sidepipess. Can't get rid of the golden hue. Well, I can, but as soon as you put a couple of heat cycles through it, they turn gold again....YUK.
So with the big spacer I built (with the help of friend) we were able to adjust the angle of the two flanges that eliminates the need for wedges. One skinny gasket and I'm good to go. Pipes lined up perfectly. With my car up on dollies, the tips measure 8.25" to the floor on both side and I didn't have to rock the engine or anything. My engine is level to within 1/16" measured back to the frame.
Just thought I would share.
Perry
FFR #6641, Mk 3.1, 408W Stroker, Dart Block, Edelbrock Victor Jr Heads, Custom Hydraulic Roller Cam, Quick Fuel 750 CFM, Non-Donor, TKO 600, Center Force Clutch, 8.8" Detroit Tru-Trac, 3.73 Gears, S.S. Side Pipes, Polished FR500 Style Wheel, Big Ass Wilwood Brakes, VPM Reinforced 3-Link, Stainless Steel Braid Everything. POM Dec/2010 & Feb/2011.
SIZE-O is offline   Reply With Quote
