8.8 axle vent (5/16") confused... - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 10 (permalink) Old 10-06-2011, 03:36 AM Thread Starter
Lou N's Avatar
All,
My 8.8 rear axle has a 5/16" fine thread for the axle vent, does that indicate that the rearend came from a certain year Mustang or possibly a truck? I can't seem to find a Ford part for that size, everything I find is 1/8".
The rearend came with an orange plug so I'm assuming it wasn't drilled and re-tapped. Any idea if I can just run a 5/16" fitting with a hose for a vent?
Lou
MK III, Non Donor, Crate 302, 15\" American Racing Wheels, Disk/Drum, still deciding on the rest...
Lou N is offline
post #2 of 10 (permalink) Old 10-06-2011, 03:45 AM
streetbeast's Avatar
Your right it 1/8"pipe.That what it should be.Just use a vent from any 8.8 axle.
streetbeast is offline
post #3 of 10 (permalink) Old 10-06-2011, 03:59 AM
ROADRACER83's Avatar
Thread terminology
Pipe is always measured by inside diameter and tube is measured by outside diameter.
1/8th inch pipe threads are 1/8th inch inside and about 5/16ths outside due to the thickness of the pipe walls. For instance a 1/2 inch pipe thread tap is about 3/4 inch in diameter due to the approximately 1/8 inch thick pipe walls.
On my 8.8 rear end I found that the 3rd link banana bracket covered the vent hole so I welded it up and drilled a hole toward the top of the back cover and put a right angle -6 AN bulkhead fitting and a 2 foot piece of hose in as a vent. I anchored the end of the hose to the frame with a loop between the diff housing and the frame to allow the rear end to move up and down. I put a 3/8 plastic fuel filter on the end to allow the vent to breath but not suck in any debris. If the 3rd link bracket doesn't hit the vent you don't need to go to those lengths.
ROADRACER83 is offline
post #4 of 10 (permalink) Old 10-06-2011, 05:00 AM Thread Starter
Lou N's Avatar
Guys,
Thanks. I guess it is NPT, not fine thread. I found this after searching around:
Ford Rear End Breather
I think I'll look for a fitting and just run a hose as Roadracer83 suggested.
Lou N is offline
post #5 of 10 (permalink) Old 10-06-2011, 06:01 AM
Cool little vent
Jeg's has got a neat little vent with a filter in it. A 1/8 pipe fitting with a nipple on it would work also. Just use some 1/4 or 5/16 hose. NAPA has those hose fittings.
JEGS Rear Axle Vent - JEGS
This is what you are looking for but you can get them in brass for a lot less.
Holley Performance Hose Barb to Pipe Thread Adapters Products
ron
post #6 of 10 (permalink) Old 10-06-2011, 06:45 AM
Ford part number should be 4R3Z-4022-AA.
oxide is offline
post #7 of 10 (permalink) Old 10-06-2011, 03:46 PM
1fastsedan's Avatar
XXXXX - recommended part did not fit
1fastsedan is offline
post #8 of 10 (permalink) Old 10-06-2011, 09:40 PM
8.8 vent
The vent on the mustang 8.8 rear end from 1987-2004 is a special thread and come from Ford only
custom brake kits and custom powder coating
Discbrakesrus is offline
post #9 of 10 (permalink) Old 10-07-2011, 04:16 AM
How to make your life easier:
Check Breeze Automotive Factory Five Racing first
Mark Reynolds is offline
post #10 of 10 (permalink) Old 10-07-2011, 04:08 PM Thread Starter
Lou N's Avatar
Thanks guys. I'm going to stop by Ace Hardware today and try the 1/8 NPT fitting. I have a leftover filter from a bike project that will work on the end of a hose to keep the dirt out.
Lou
Lou N is offline
