Make a note of it. - FFCars.com : Factory Five Racing Discussion Forum
Old 06-13-2011, 12:00 AM   #1 (permalink)
Master Student
Doug Meldrum's Avatar
Make a note of it.
Go through your motor and re-tighten all your bolts after you've heated it up or you'll get what I got. I ended up blowing a header gasket.
Put this under "don't do this" and "Awe Crap".
D
FFR #7228, under construction
Doug Meldrum is online now   Reply With Quote
Old 06-13-2011, 12:34 AM   #2 (permalink)
Arch F's Avatar
Thanks. I have a rather large "don't do this, awe crap" file
Arch
Graduation POM 3000 Mile Trip
3500 Mile Trip
Arch F is offline   Reply With Quote
Old 06-13-2011, 03:47 AM   #3 (permalink)
Finallygotit's Avatar
Thanks, good advice. Unfortunately for me...... been there, done that then bought Percy's bolts so I didn't have to go through it again. So check yer bolts always.
FFR6043 Delivered 04/29/07 Mk III, Non-donor, IRS w/3.55 Traction-Lok, Levy SD T-5, 302/345HP Mass-Flo, Team III/Sumitomo 315/35R17, 255/45R17, FFMetal Grand Slam, Wipers, Heater, everything Russ Thompson sells for a roadster, Damplifier, Earl's Vents. Paint by Jeff Miller (da Bat) Ford Merlot Metallic (FX). Graduated 08/29/10.
http://www.ffcars.com/forums/17-factory-five-roadsters/255392-presenting-ffr-6043-graduation-grad-50-2010-a.html
Finallygotit is offline   Reply With Quote
Old 06-13-2011, 04:14 AM   #4 (permalink)
I havn't used an exhaust manifold gasket in years. High temp silicone only. But I do take the time to check those bolts pretty often. Every once in a while, I'll find one loose.
People have the same problem with intake manifold gaskets. The gaskets often compress well, but then later I'm not sure what happens, and the bolts are loose. That's when the gaskets fails. I go around and tighten in the bolts in the proper pattern, about 6 times. I wait about an hour or two, and do it again. I'v never had a failure there.
Old 06-13-2011, 05:59 AM   #5 (permalink)
AC Bill's Avatar
Doug, that's a real drag!
Seems common place with the stock bolts and gaskets, unfortunately...
The Percy split locks do seem to be a good investment, and if you can find them, try the Remflex gaskets. Good product, and I haven't heard of a failure with them yet..
AC Bill is online now   Reply With Quote
Old 06-13-2011, 12:43 PM   #6 (permalink)
Wannabe Roadster Builder
PGreenSVT's Avatar
Hi temp silicon only works great. A dab of Loctite helps to keep from coming loose. Splitlocs work well too.
PGreenSVT is offline   Reply With Quote
Old 06-13-2011, 01:17 PM   #7 (permalink)
We know what you're up to
Don Payne's Avatar
Doug, are your header flanges flat? You probably have BBK's, but my Hookers need some love on a belt sander to correct the waviness of the flange.
-Don
Old 06-13-2011, 01:33 PM   #8 (permalink)
BigLeo69's Avatar
Icon21
i will ditto that on the hookers the mating surface sucks
well not to mention getting a good torque on the header bolts, with stage 8 bolts, copper rtv, i still came up with exhaust leaks all out the bottom.
i have been thinking of Gordon's headers.
"Torque is the grunt
MK3.1 #6945 her name is Buffy
p/u 04/04/09 roller 08/27/09
go-cart Memorial Day 2011
body on 11/11/11 Veterans Day
372w handbuilt
Old 08-04-2012, 08:41 PM   #9 (permalink)
Master Student
Well here we go again... I just noticed an all too familiar popping sound coming from my headers... AGAIN! I put in stage 8 bolts last time, which have been great, but the leak is coming from the same place my first leak came from. I have replaced four header gaskets now. I thought the bolts would solve the problem. I will admit, the latest gaskets were just stock Fel-Pro gaskets. This time I will take a look at my headers to see if it's warped.
Any tips on gaskets to use? I not convinced the silicone is the best solution because of goo-ping silicone or the mess to deal with... I also don't want to dis assemble the pipes to install new gaskets due to the awkward pipe/header install.
Old 08-04-2012, 08:54 PM   #10 (permalink)
rscocca's Avatar
Remflexs gaskets and Percy split bolts, Three years no leak, no loose bolts.
Damn, I just jingst myself
CLASS OF 2009 # 79 FFR MK 3.1, # 6898, Complete kit arrived 02/07/09, roller 03/30/09, first start 07/14/09, Registered 10/14/09, PPG Orange Glow over Sterling silver, Dart aluminum 427W, stack fuel injection,on board fire supression,Front Runner Serp system, TKO 600 mid shift mod, ISIS system, Hydroboost brakes with Willwood pedals, PS, A/C, IRS, Griggs racing front suspension, Foot box mods both sides,Dark Water splitter,dead pedal,glove box. (where's my publisher) Lots o Goodies
http://photobucket.com/rscocca
rscocca is offline   Reply With Quote
Old 08-05-2012, 06:11 PM   #11 (permalink)
Hey Doug,
I've reused the same Remflex Ex. gaskets on 3 diff. motors with stock ARP header bolts. No leaks with BBK Headers. Works fine for me.
hth
Butch
Butch B is offline   Reply With Quote
Old 08-05-2012, 10:00 PM   #12 (permalink)
Don Payne's Avatar
Seriously Doug, get your flanges sanded flat!!! Messing with gaskets, bolts and RTV will not compensate for a poor mating surface. It only cost me like $30. FYI, don't use gaskets...just copper RTV.
-Don
Old 08-05-2012, 10:06 PM   #13 (permalink)
trevor's Avatar
I bought the percys layered aluminum gaskets about 3 years ago. I havent had a problem since then. I re-tightened one time after the first heat cycle. Never touched anything again. I used to blow the stock gaskets all the time, also had the bolts loosen up too.
Old 08-05-2012, 10:40 PM   #14 (permalink)
cobrajj's Avatar
My results are the same as BUTCH B. I checked & had to re-torque a few of the ARP bolts after one heat cycle--that was two years ago. Jim
cobrajj is online now   Reply With Quote
