Questoin about hi-temp silicone sealant for exhaust - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 10 (permalink) Old 02-16-2011, 04:43 PM Thread Starter
Pierre B.'s Avatar
I have read here on several occasions that a bead of hi-temp silicone sealant will do as well as or better than gaskets for sealing the gap between our side pipes and the end of the cats/J-pipes/header. I have never heard details about how the sealant should be applied. Here's what I mean specifically.
I used a similar bead of sealant to seal my Canton oil pan to the bottom of the engine some time ago. There, I laid in the sealant bead around the top of the pan, then waited 24-hours for the silicone to setup with the pan free of the block; and only after that did I bolt the pan up tight to establish the seal. I wonder if the sealant application at the side pipe connection needs to be made the same way in order to do the job best. Otherwise, the option is to apply the sealant and immediately smoosh the joint tight with the bolt connections. I would like to know what other builders have done here. It seems like a good idea to pitch the gaskets if the sealant work as well or better.
Pierre B
Pierre B. is offline
post #2 of 10 (permalink) Old 02-16-2011, 05:10 PM
CobraDVM's Avatar
I'm curious about this as well - my headers are supposed to arrive today.
Howard
Dart 427W, IRS,T56 6 speed,
Sept 2010. Best E.T 11.72 @ 121.66
FFR 6817 // Delivery Date: 11/20/08 // Roller: 9/25/09 // First Engine Start: 3/31/10 // Gokart: 4/11/10 // Painted: 7/2/10 //Graduated 10/03/10. Graduation thread with my progress links is
CobraDVM is offline
post #3 of 10 (permalink) Old 02-16-2011, 05:52 PM
To my best recollection, apply a bead of silicone wait 1/2 to 1 hr then bolt it together. I just bolted mine together loosely waited an hour then tightened it, no problems.
rich grsc is offline
post #4 of 10 (permalink) Old 02-16-2011, 07:38 PM
FFR Craftsman
289FIA_Cobra's Avatar
This reminded me of an "old" Permatex testament of someone building a motor completely from Permatex. I couldn't remember so I Googled it and Permatex has a history of this:
http://www.permatex.com/about_history.htm
I had no idea it had such humble beginnings.
289FIA_Cobra is offline
post #5 of 10 (permalink) Old 02-16-2011, 10:17 PM
Dave M's Avatar
Rich has it closer. Not sure of the actual recommended time, which may vary a little between products, but go by what it says on the package. Letting it harden for to long could cause a no seal problem as you might end up with small lumps unless you are extremely good at getting a purfectly even bead all the way around. This would be more of a problem on thin things like pans and valve covers but you never know.
Dave M is offline
post #6 of 10 (permalink) Old 02-16-2011, 11:18 PM
BigLeo69's Avatar
copper hi-temp rtv
i used some studs to align the headers so as not to mess with the sealant.
secured the headers with some stage 8's ohhhh that was fun. pulled the studs out and finished the bolt up.
used copper hi-temp anti-seize on the stage8's with aluminum heads, had the hi-pressure lube i used before, but decided to use the anti-seize.
"Torque is the grunt
MK3.1 #6945 her name is Buffy
p/u 04/04/09 roller 08/27/09
go-cart Memorial Day 2011
body on 11/11/11 Veterans Day
372w handbuilt
BigLeo69 is offline
post #7 of 10 (permalink) Old 02-17-2011, 12:25 AM
Bobasaurus's Avatar
I use "Ultra Copper" and it staes to use a 1/8" bead and assembly immediately. That's the was I do it and have never had any problems.
Graduation 8/26/06
Status: 31842 miles
Vortech Supercharged 4/5/2010
Bobasaurus is offline
post #8 of 10 (permalink) Old 02-17-2011, 01:39 AM
The problem w/ letting the silicone dry too much is that it will only be adhered to the one part that it was applied to. It won't be adhered to the second part. So you have a bead that is on one part,that is varying thickness due to normal human hands being what they are, and then it is simply compressed between the parts. This would,it seems to me give you a seal similiar to what you get when one of the parts isn't clean and dry. I can't think of any applications where this would be a good procedure.My experience says that both surfaces must be clean and dry so the silicone will adhere to both.
CraigS is offline
post #9 of 10 (permalink) Old 02-17-2011, 01:41 AM
CobraDVM's Avatar
Good idea - I'll cut the heads off a couple of bolts and use them as studs.
Howard
CobraDVM is offline
post #10 of 10 (permalink) Old 02-17-2011, 02:55 AM
I gave up using header gaskets a long time ago; silicone only.
On the J pipes, I would only use silicone between the J pipe and side pipe. But at the header connection, it's designed to use a donut gasket to make allowance for any misalignment. I would use a donut gasket, but then add silicone at the contact surfaces.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
Bob Cowan is offline
