Fuel filter? 10 or 40 Micron??? - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 6 (permalink) Old 01-30-2011, 11:54 PM Thread Starter
I am in the middle of redoing allot of things on my car.
Fuel lines being one of them.
I am going with -8 lines from the fin tank pump pick up bracket all the way to the fuel rails with a -6 return.
I am installing an in line filter, I see the two most popular sizes for the filter elements are 10 and 40 microns.
SET UP.
255 High pressure in tank pump.
-8 feed lines
-6 return lines
Aeroquip fuel rails and pressure regulator
42 pound injectors
What should I go with?
JOhn
ΜΟΛΩΝ ΛΑΒΕ
Cobra 302 is offline
post #2 of 6 (permalink) Old 01-31-2011, 12:50 AM
10 micron after the pump
if you have an inline pump use a 100 micron befor the pump with a 10 micron after the pump.
acmikee is offline
post #3 of 6 (permalink) Old 01-31-2011, 01:04 AM
I use the 40 micron before the pump, and 10 micron after the pump.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
Bob Cowan is online now
post #4 of 6 (permalink) Old 01-31-2011, 01:06 AM Thread Starter
OK I have the in-tank pump so I am going to go with the 10 micron filter.
ΜΟΛΩΝ ΛΑΒΕ
post #5 of 6 (permalink) Old 02-01-2011, 12:34 AM
Builder of OVERKILL!!
2fastCobra's Avatar
Talking
I have 40 micron before the pump, and 10 micron after the pump.
FFR turbocharged 408W Dart Iron Eagle block 225 AFR race heads. Methanol injected, 83mm T6 turbo. Dyno numbers 924rwhp / 986rwtq *** dyno video***
2fastCobra is offline
post #6 of 6 (permalink) Old 02-01-2011, 01:04 AM Thread Starter
How is the turbo rebuild going?
Thanks for the info.
ΜΟΛΩΝ ΛΑΒΕ
