My Trunk Striker Mod - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 23 (permalink) Old 12-19-2010, 07:50 PM Thread Starter
65_427_COBRA's Avatar
I saw Chris P.'s (ILM MK3) trunk Mod and decided to try my own. For a long time I was unimpressed with the FFr "Trunk Striker " screw then I saw something on my friends 99 Honda Accord and thought,
" Hey............."
So here's mine.
Striker is the Door striker from a 99 Honda Accord about $12.00
The plate under the trunk is a piece of scrap 1/4 x 3 x 4 secured with # 14 x 1 self tapping screws to the lower 3/4 trunk tube. The striker is held in place with two 5/16-18 x 1 Stainless machine screws and nylock nuts.
Another plus is when the latch latches, now it "clicks" into place.
Dad, can I drive it????... Ever!!
FFR1467K 5.0L, Mass-Flo, T5, Trigo Wheels, Lexus Spectra Mica Blue, Phantom stripes and Smiths Gauges.......
65_427_COBRA is offline
post #2 of 23 (permalink) Old 12-19-2010, 08:14 PM
Husband/Father/Son
mrmustang's Avatar
That is an outstanding idea, really ads a level of safety over the stock latch/rod combination.
Bill S.
mrmustang is offline
post #3 of 23 (permalink) Old 12-19-2010, 08:22 PM
So you are still using the regular FFR latch assembly?
CraigS is offline
post #4 of 23 (permalink) Old 12-19-2010, 09:12 PM
Joe
Senior Mem / Moderator
Joe's Avatar
Ditto.. I'm confused.. What clicks? Lets see the other half of the latch that you're now using.
Joe - Texas Cobra Club - DFW
Joe is offline
post #5 of 23 (permalink) Old 12-19-2010, 10:22 PM Thread Starter
Everything else is still the same. Still using the stock FFR latch assy. I guess the click comes from the latch fitting the diameter of the striker better. It just feels more secure, more positive.
post #6 of 23 (permalink) Old 12-20-2010, 01:39 AM
na
Send a message via AIM to hotmansweep
I used a 1/4 inch u bolt but that looks much cleaner
hotmansweep is offline
post #7 of 23 (permalink) Old 12-20-2010, 05:23 PM
AC Bill's Avatar
Great idea! Looks very professional compared to the FFR striker system.
Does it prevent the trunk lid from tweeking slightly to one side when you tighten the latch up? I have that issue currently, and need to figure out what needs to be adjusted to prevent that.
AC Bill is offline
post #8 of 23 (permalink) Old 12-20-2010, 06:26 PM
ILM MK3's Avatar
65 427 COBRA, good job and thanks for the credit on the bottom brace, I really wonder if I was the first but I have never seen it. Its a much better and stronger solution to the FFR striker. You can shut and lock your trunk with confidence.
Bill, yes it does help this, it was the crappy fit that got me started down the path. Its easy to line up becuase you dont rely on predrilled holes in either the body or the aluminum. I was planning on making larger holes with a plate sandwiched between to cover them to give myself some adjustment, but it ended up I didn't need any (it was really easy to get right the first time). Just mound the plate under the car first and then open the trunk, put the latch in the closed postions and eyeball where the striker is needed left to right (you could mark it on some masking tape).
I used a 316 stainless boat cleat, here is mine in another thread. I have since put shorter SS bolts through the cleat. I like the cleat because you can use it as a solid tie down point as well or loop something through it.
Chris P.
MKIII.1, Forte's 351W Carbed, TKO600 Midshift, SAI, IRS -- Ordered 1/12/09; In the garage 3/1/09; Rolled for the first time 6/16/09
ILM MK3 is offline
post #9 of 23 (permalink) Old 12-20-2010, 06:31 PM
Finallygotit's Avatar
Originally Posted by mrmustang View Post
That is an outstanding idea, really adds a level of safety over the stock latch/rod combination.
Bill S.
I totally agree! Too bad my car is finished.
FFR6043 Delivered 04/29/07 Mk III, Non-donor, IRS w/3.55 Traction-Lok, Levy SD T-5, 302/345HP Mass-Flo, Team III/Sumitomo 315/35R17, 255/45R17, FFMetal Grand Slam, Wipers, Heater, everything Russ Thompson sells for a roadster, Damplifier, Earl's Vents. Paint by Jeff Miller (da Bat) Ford Merlot Metallic (FX). Graduated 08/29/10.
Finallygotit is offline
post #10 of 23 (permalink) Old 12-20-2010, 07:11 PM Thread Starter
Dan, I just did this mod yesterday, my car has been finished for 4 years now. This is a mod that can be done on a finished car.
post #11 of 23 (permalink) Old 12-20-2010, 08:51 PM
iBuild
Someday I Suppose's Avatar
Steve, got a part number?
Titled and legal July, 2011
Someday I Suppose is offline
post #12 of 23 (permalink) Old 12-21-2010, 04:08 AM Thread Starter
Someday, Sorry I threw away the bag, But if you ask for a 99 Accord striker I am sure the Honda dealer in your area can find it.
post #13 of 23 (permalink) Old 04-10-2011, 01:30 AM
ThreePointTwo's Avatar
I love this idea and I came up with a slight variation of it for my rig. This is just a stainless steel U Bolt from Lowes.
MK III, 427W, midshift TKO 500, 4 link, 3.73 gears, 315/275 tires.
ThreePointTwo is offline
post #14 of 23 (permalink) Old 04-10-2011, 01:41 AM
CobraDVM's Avatar
Great ideas - I like the idea of the U Bolt from the hardware store - I think it probably allows for a bit of adjustability if the Honda one doesn't fit quite right.
Howard
Dart 427W, IRS,T56 6 speed,
Sept 2010. Best E.T 11.72 @ 121.66
FFR 6817 // Delivery Date: 11/20/08 // Roller: 9/25/09 // First Engine Start: 3/31/10 // Gokart: 4/11/10 // Painted: 7/2/10 //Graduated 10/03/10. Graduation thread with my progress links is
CobraDVM is offline
post #15 of 23 (permalink) Old 04-10-2011, 02:02 AM
SnappyT's Avatar
I made a catch and spring loaded it so it not only latches the trunk but also pulls it down for a better fit.
You don't stop playing when you get old - you get old when you stop playing
SnappyT is offline
post #16 of 23 (permalink) Old 04-10-2011, 02:37 AM
"The" FFR Master
Joe Camire's Avatar
Thumbs up
I like this mod I wish I could do it. I have a spec and there is a tube right under that part of the trunk. HMMMM I wonder If I could mount it to the tube??? I will work on that. Great work guys.
Joe Camire
A.S.E. Master Automotive Technician
A.S.E. Undercar Specialist
A.S.E. Parts Specialist
A.S.E. Service Consultant
FFR Tech Support 1999-2003
Paint and body work done in 6 Days!!!
It's just a pile of parts until you have the first start. Then it is a car!!
Joe Camire is offline
post #17 of 23 (permalink) Old 04-10-2011, 03:00 AM
I'd like to see that. How 'bout some pics?
SL-C in progress....
dallas_ is online now
post #18 of 23 (permalink) Old 04-10-2011, 06:12 AM
SJDave's Avatar
How do you adjust the height of the latch?
Great Timing...I installed the Darkwater trunk storage boxes so the standard FFR bolt will not work, can't get to the back to install the nut. I was just trying to figure out a latch today in the garage and here's this post! I like the look of the Honda part, do you need to adjust the height of the striker or is it just right as Honda made it.
Dave
" Hey............."
So here's mine.
SJDave is offline
post #19 of 23 (permalink) Old 04-10-2011, 12:24 PM
Gelcoat Driving Maniac!
BigRedRPB's Avatar
So......not to knock this mod, but what am I missing? What's wrong with the bolt that FFR uses? It's always felt pretty sturdy to me.
Kevin
#6327 -
02/07 -
04/22/07 -
08/13/07 -
10/10/07 -
11/08/08 -
11/25/08 -
03/28/09 - Registered/Insured 07/07/09 - First Actual Drive 07/10/09 -
07/14/09 (my 30th B-day) - Sold 11/20/15
MKIII, IRS, 31 Spline - 3.55 Rear, Levy Stage 5, Holley 750 Carb, Levy Super Alloy T-5 w/Midshift, FFR Headers, Color TBD.
BigRedRPB is offline
post #20 of 23 (permalink) Old 04-10-2011, 12:56 PM
"The" FFR Master
Joe Camire's Avatar
Thumbs up
The mod just gives it an OE look and feel that is all.
Joe Camire
post #21 of 23 (permalink) Old 04-10-2011, 03:10 PM
SnappyT's Avatar
Here's a picture of my mod. The FF design didn't hold down the trunk tightly. This catch is adjustable up and down. There's just enough "give" in the springs so that it goes up when the latch is being rotated and then pulls the trunk lid down for a tight fit.
SnappyT is offline
post #22 of 23 (permalink) Old 11-03-2016, 11:49 PM
Actual builder now!
Slord's Avatar
Plus if you have done Jeff Kleiner's mod for the rear quick jack bolts to make the body removable without dropping the gas tank then this eliminates having to drop the tank to remove the striker pin as well.
Slord is offline
post #23 of 23 (permalink) Old 11-04-2016, 05:53 PM
Avalanche325's Avatar
Just put a rivnut in and don't use the nut.
MKIV Roadster....FFR7694
Avalanche325 is offline
