Bringing Dead Optima Batteries Back to Life - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 35 (permalink) Old 08-04-2010, 12:19 AM Thread Starter
The September, 2010 issue of Hot Rod Magazine "A Current Affair" (pages 74-76) article is well worth reading for those with AGM batteries such as Optima and I guess Odyssey. The article explains what happens when these type of batteries become discharged to the point that they won't recharge.
The detail of the article says the problem with deeply discharged batteries is that most battery chargers can not recognize the battery is present when the voltage is less than 4 and thus doesn't go into the charging mode.
I had this deep discharge happen to me with a six-month old Optima red top battery during my build. After working on the electrical one day I forgot to turn off the switch and went on vacation for long spell. When I got back the battery was dead and would not recharge. Luckily it was under warranty from O'Reilly and they replaced it. Of course I never admitted to O'Reilly what I had done or I'm guessing the warranty would be voided.
For those that don't have access to the magazine here's the summary:
"When an AGM battery won't charge by ordinary means, simply connect a second, well-charged battery (12.4 volts or better) in parallel with the dead unit - positive to positive, negative to negative. Then connect the charger to the pair. This will in effect trick the charger into delivering the necessary current to the discharged battery. Using this method, we brought several deep-discharged batteries back to life. Bye the way, this trick also works with conventional batteries, through it's not quite as effective."
I'm sure I'll drain a battery sooner or later and I'll try this method before digging out the receipt for the battery and going through the replacement process. Hope this helps someone in the future. Jim
FFR#6735 - 3.1, E4 Red, 347, 680 Quick Fuel carb, Modified C6 auto, 3.55, 3 link, AM wheels with Sumitomo HP tires, Damplifier Pro, Veneer dash with vintage gauges, heater, wipers, ceramic exhaust, CobraEarl fresh air vent. Delivered 9/08, painted 12/09.
Warsaw Jim is offline
post #2 of 35 (permalink) Old 08-04-2010, 01:51 AM
Good tip!!! But do you hook up the charger to the discharged battery or the charged battery, if it makes any difference?
Rob
Roadster Mk3 #6303 Sold
Coupe #056 Built for customer and gone
Roadster Mk4 del. 12/2/15
Pin drive, IRS old style, Trigos w/15" tires (what else!)
Levy 427, dual quads, alloy t5, Willwoods, and yes a
stereo
robanno is online now
post #3 of 35 (permalink) Old 08-04-2010, 02:18 AM Thread Starter
I believe the article shows the battery clips attached to the battery you are trying to charge but since it is hooked in parallel to the fully charged battery I'm not sure what difference it makes except the article says "After an hour or so you can remove the second battery and continue with the charge".
The article also recommends the use of "float chargers" or "battery tenders" which deliver a small but constant charge to keep the battery fresh and fully charged. -- "We've seen basic units for sales for around ten bucks".
I have a couple of friends with custom cars that typically don't start them for months at a time and use the "battery tenders" successfully.
I've seen threads mentioning remote battery connections to make it easier to connect the chargers. My battery is in the trunk and I have to pull four screws to get to the battery. Not a big deal but if I were doing it again I would have probably added remote battery connectors.
post #4 of 35 (permalink) Old 08-06-2010, 05:12 AM
Administrator
David Borden's Avatar
Man, good timing, I have hope! I killed a Optima recently but didnt toss it. Thing looks brand new... I'll try this tomorrow and report if it works.
Mk4 Build Thread:
GTM Project Build site:
David Borden is offline
post #5 of 35 (permalink) Old 08-06-2010, 12:00 PM
MJN
MJN's Avatar
My son drained the Optima in my truck down to nothing. I jumped the truck and ran it around to charge the battery. The battery would start the truck right after it had a charge in it but the next day it was dead again. I have been told that they need a high amp hook up to get them to take a charge so I'm not sure why the alternator which is a 120 amp unit didn't do the job.
Mike....
MJN is offline
post #6 of 35 (permalink) Old 08-06-2010, 05:29 PM
Blues n Brews
ewh123's Avatar
I have heard that a Battery Tender or similar type chargers need to see a minimun voltage on the battery being charged. Hooking up a battery in parallel fools the charger that there is a minimum voltage present in the battery being charged.
ewh123
ewh123 is offline
post #7 of 35 (permalink) Old 08-06-2010, 05:34 PM
Jetsbaby's Avatar
I read the article..They used a Harbor Freight charger..You "fool" the charger with hooking up a charged battery in parallel so it will charge the dead one..Once the battery is charged past six volts it can be normally charged..
Jetsbaby is offline
post #8 of 35 (permalink) Old 08-06-2010, 06:00 PM
beeman's Avatar
I have had an optima red top in my twin turbo Nissan Z for about 4 years now. If the car sits for more than a couple months (ie winter storage), the battery is inresurrectable. Maybe my trickle charger is incompatible?
EDIT: Nice to have this info, will try it out.
MK3.1 2004 Mach 1 donor. PS, PB, ABS, TC.
GTM #304
2000 C5 Coupe 489HP LS1
beeman is offline
post #9 of 35 (permalink) Old 08-12-2010, 04:03 PM
Hello, I noticed your conversation regarding our batteries and wanted to offer some assistance. The parallel charging technique described in the story Warsaw Jim mentioned is also explained in this video- http://www.youtube.com/watch?v=dIoaL3DWWEg
The threshold for recognizing a battery varies from charger to charger, so we generally suggest charging the deeply-discharged battery above 10.5 volts before disconnecting the healthy battery. Although the article doesn’t specifically mention it, this situation is not unique to Optima or any other AGM battery. This is an issue specific to many battery chargers. Jim, don’t feel bad about not being forthright with O’Reilly on your warranty claim. Many of the “bad” batteries returned to us now are just deeply-discharged. Although some manufacturers have dealt with this by simply voiding the warranty on their batteries if they have been discharged below 10 volts, our retailers are supposed to charge and check all returned batteries for this condition, prior to making an exchange.
Since the batteries are wired in parallel, it doesn’t make a difference how they are connected, although it might be easier to wire the deeply-discharged battery in the middle. That way, when it does reach an appropriate voltage level, you can just disconnect the healthy battery and continue charging the deeply-discharged battery.
The key to long battery life (regardless of brand), is to make sure your battery is always maintained with at least 12.4 volts, whenever possible. When batteries are discharged below that level, sulfation begins to diminish both performance and lifespan. That makes a battery tender or maintainer an excellent investment for any vehicle that is not driven daily.
Most alternators are designed to maintain batteries, not recharge deeply-discharged batteries. If a battery is discharged to the point where it needs a jump, we recommend fully recharging the battery with a battery charger as soon as possible. Relying on an alternator to recharge a deeply-discharged battery can lead to a cycle of dead batteries and jump-starts, until either the battery or alternator fails. Mike, we do not recommend using high-amp units like the one you described, as they can “cook” a battery. For regular charging, we recommend a maximum of 10 amps at 13.8 to 15 volts.
I should also mention that even though our batteries have a “sealed” design, all lead-acid batteries can vent gas. Under normal operating conditions, an AGM battery will not vent gas. Since alternators or chargers can fail, the safest and correct mounting method for trunks and passenger compartments is to make sure that any possible gas venting will escape to the outside of the vehicle. All vehicles with original equipment battery locations in trunks or passenger compartments will have a vent provision that should be used.
Our group 27, 51, 78, 34C, and 31 batteries all have ports for connecting a vent hose. Although people do it anyway, we would never recommend installing an unvented battery in any enclosed space, because there’s a legitimate, albeit unlikely, safety risk involved.
For example, IF there is a voltage regulator failure, and IF the battery is severely overcharged, and IF this goes unnoticed, and IF the battery vents because the internal pressure exceeds the release pressure of the vents, the gasses are both flammable and toxic. This may sound like a lot of “ifs,” but attorneys and engineers get paid to plan for every worst-case scenario. If you have any questions about our batteries, please don’t hesitate to ask.
Jim McIlvaine
eCare Manager, OPTIMA Batteries, Inc.
www.facebook.com/optimabatteries
OptimaJim is offline
post #10 of 35 (permalink) Old 08-12-2010, 04:06 PM
Hand Jabba the Hut
Nemo's Avatar
Thanks for joining us Jim. I would bet that around 50% of us owners are using your batteries. Please don't be a stranger!! Welcome aboard.
Click for :
- SOLD
Videos:
Nemo is offline
post #11 of 35 (permalink) Old 08-12-2010, 05:31 PM
MJN
MJN's Avatar
Jim.
Thanks for taking the time and for providing great information. Do you have a good link for 'care and feeding' of your batteries?
Mike....
MJN is offline
post #12 of 35 (permalink) Old 08-12-2010, 05:31 PM
33 Moderator
geoffav's Avatar
The article
http://www.hotrod.com/techarticles/g...ery/index.html
Geoff
FFR 33HR #037 slow build
2002 Mustang GT (TT'd 630rwhp Sold)
2003 Mach1 Azure Blue (Sold)
2004 Mach1 Torch Red (modified and sold)
2014 Mustang GT (Track Pack) in Black
geoffav is offline
post #13 of 35 (permalink) Old 08-12-2010, 08:54 PM
cobradawg's Avatar
Well I guess Beeman has a little egg on his face now. I've had a red top in my cobra for 5 years now, I give it a little shot with a trickel charger when ever it has set for a while, and all is good. Thanks for the great info Jim.
FFR# 4834K, 302 EFI, 3.55, FMS Y 303 heads, E303 cam scorpion rockers, 4 link with coilovers
cobradawg is offline
post #14 of 35 (permalink) Old 08-12-2010, 09:06 PM
rem6a's Avatar
I am sure the above jumping technique works, but you could always purchase a battery charger with a Type-I and Type-II charging abilities. I purchased a dual charger some time ago and it works for the deep cycles. We were having issues with gel or deep cycles holding a charge after winter. The Type-I was not producing a deep enough charge for some electro physics reason. Purchased the dual charger and have 4 years going on the batteries. Works on the new motorcycle batteries for EFI, deep cycle and marine.
I am the guy the track Marshall warned you about.
Video of my Shelby
rem6a is offline
post #15 of 35 (permalink) Old 08-12-2010, 09:19 PM
Ian G's Avatar
To add to this- this trick works for wet cell batteries also. I learned to do this back in ths 60's when I was working in a service station. Over the years since, I have resurrected many batteries that others have thrown out.
- Ian G
FFR 5509RD
Ian G is offline
post #16 of 35 (permalink) Old 08-13-2010, 12:53 AM
Big-Foot's Avatar
This does work on many batteries...
I have used another trick -
Put some jumper wires on a taillight bulb and hook it up to the battery - this will cause a load on the battery charger and cause it to feed current into the battery.
Regards - Randy
Racecar Fab/Support
69 Camaro SS 4spd
My GT-40 Build Site:
Big-Foot is online now
post #17 of 35 (permalink) Old 08-13-2010, 07:23 PM
Thanks for the welcome guys, I’m happy to help out. Our YouTube channel has several different videos on proper battery selection, care and maintenance, including this one- http://www.youtube.com/watch?v=Z40SQCKWKNw
Since rem6a mentioned the “g” word, I should clarify that Optima batteries are not gel batteries. In most situations, a regular battery charger will work just fine on Optima batteries, but charging Optima batteries on “gel” or “gel/AGM” settings will not fully-charge an Optima and could damage it over time.
Jim McIlvaine
post #18 of 35 (permalink) Old 08-14-2010, 02:48 AM
SR71's Avatar
...great tips but too late for my Optima ....I swallowed the hook and bought an Optima..... it really never saw any use - I purchased it ...left it on a shelf for something like 16 months and I guess it just died....I could not charge it and the local Autozone could not either. I will point out that I was given a pro rated replacement value on the warranty remaining.
I'll assume that many have had better experiences but for me that was too much hassle for a top dollar battery. Back to regular batteries for me.
Jim: Correct me if I am wrong but I thought the big selling point of spiral cell batteries (Optima) is the ability to hold a charge for long periods of shelf life....this is what I thought I paid for? Anyway.... I was so pissed off that my new Optima bit the dust that I walked away from the technology. Bring me back to the club.... why should I spend the big bucks on an Optima?
Regards
Kevin
Cobra Sold….63 Grand Sport on the horizon
My Cobra Website:
SR71 is offline
post #19 of 35 (permalink) Old 08-14-2010, 03:47 AM
33 Moderator
geoffav's Avatar
I don't remember what year it was but I bought a Super Gas 1969 Nova from a friend who moved up to Super Comp. He kept the motor so I put together a 500+ CI BBC and upgraded some of the systems. We installed one of the early Red Tops. That thing was abused for 5 seasons and was doing fine when I sold the car. Every time we had a battery issues with one of the cars or trucks we would steal the RT out of the race car and use it until we could replace the battery. I picked up a Blue Top a friend was going to use in his camper for real cheap and it's going in my hot rod. I've had 4 Optima batteries in the last ten years or so, no issues at all.
Geoff
geoffav is offline
post #20 of 35 (permalink) Old 08-14-2010, 05:00 AM
Administrator
After watching the Optima video on youtube on bringing their batteries back, I decided to buy a CTEK 7002 battery charger. It has a mode for restoring batteries and the guy from Optima said its great for bringing their batteries back.
The Optima had 5 volts when I started. Just a couple hours into an approx 4 hour process the battery was back to 11.5 volts... so its coming back... Yeah!
Mk4 Build Thread:
post #21 of 35 (permalink) Old 08-15-2010, 02:34 PM
If its a red top, it probably is toast, unfortunately. (Ironically, I think I just toasted mine two days ago when I left my headlights on.)
I've been using Optima batteries for fifteen years in all my various custom cars, and while the yellow tops can handle a deep discharge, I've never had a red top survive a drop that low in voltage. It'll charge, it'll seem to be holding it for a while, but it won't last. In fact, before I started standardizing on building in trickle chargers in my cars, I was going through a red top a year because of that.
I almost went yellow top this time, but since I started building in the chargers so I can plug cars in over the winter, I haven't killed a red top. Figures I did it this time with the headlights.
Hopefully you have better luck. They're great batteries, definitely my battery of choice. They just can't deal with deep discharges.
1968 Porsche 911L (sold!)
2007 Mazda MX-5 Miata Touring w/ Suspension Package (temporary roadster)
FFR #6016 (Boss-EFI powered 351w, IRS, yadda yadda zoom zoom)
George H is offline
post #22 of 35 (permalink) Old 08-17-2010, 06:44 AM
Hi Kevin,
I'm not a sales guy, but I'll do my best to at least explain good battery storage procedures. Our batteries can hold a charge for much longer periods of time than conventional flooded batteries, but a lot of factors enter into the equation. While it's ok to store any modern battery on concrete, batteries do better in cool, dry locations. Extreme temperatures (both hot & cold) will accelerate discharge rates and shorten battery life. Also, when storing a battery that is disconnected from any power source or parasitic draw, the battery should be fully-charged (approximately 12.6-12.8 volts for RedTops and 13.0-13.2 volts for YellowTops). All stored batteries will slowly discharge, so they should also be checked every few months, to make sure they are maintaining at least 12.4 volts.
As I mentioned before, when batteries are discharged below 12.4 volts and are allowed to sit in that state for extended periods of time, they will experience both diminished performance and lifespan. If your battery does get discharged below 10 volts, we won't void your warranty simply for that reason and if you do need warranty service, you don't have to ship your battery anywhere if you bought it at a local retailer.
There are a lot of other selling points for our batteries, but one of the most-popular features is the "sealed" design. This both minimizes the chance of acid damage on your vehicle, while allowing users to mount our batteries in nearly any orientation (except upside down).
Whether you buy another one of our batteries or not, if you can maintain at least 12.4 volts in the batteries you do have, you should see longer life and better performance.
Jim McIlvaine
post #23 of 35 (permalink) Old 08-17-2010, 06:59 PM
Administrator
You might be right. Purchase the CTEK 7002 charger feeling confident it would come back and I dont think it did. I'll check voltage again tonight but the charger didnt get out the charge mode even after charging for 24 hours. Cant imagine it would take that long.
Optima Jim, is there any way to get a warranty replacement on a battery I dont have a reciept on? Is there a code on the battery or something? The battery is nearly new, just dont have a receipt.
David
Mk4 Build Thread:
post #24 of 35 (permalink) Old 08-19-2010, 02:28 PM
Hi David,
I’m sorry to hear about the problems you’ve been having. If you are using a CTEK charger, I would just give it some time. The CTEK manual even specifically indicates that a sulfated battery will only accept current with difficulty and as a result, the charging process on such a battery could take a particularly long time. It also mentions that it could take up to three days for the charger to switch over to maintenance charge mode.
If you do end up needing warranty service, having the original receipt does make the process easier. If you don’t have the receipt, but have some form of proof of purchase, such as a cancelled check or credit card statement with sensitive information blacked out, I can probably help you. Many retailers will also keep computerized records of purchases, so if your battery is nearly new, there’s a good chance they will still have a record of your purchase. Please keep me posted!
Jim McIlvaine
post #25 of 35 (permalink) Old 03-30-2015, 10:20 PM
Administrator
Larry N. Johnson's Avatar
Do this is an old thread, yes.
Where are we on resurrecting these Optima Batteries?
The Optima video on You Tube confirm the two-battery trick. I read on the Porsche Forum that it may take 3-4 days of charging. The key is checking your battery voltage after a while then remove the parallel battery if the voltage is high enough for your charger. Is that thresh hold 6 or is that 10 volts?
Larry N. Johnson is offline
post #26 of 35 (permalink) Old 03-30-2015, 11:18 PM
TD
TD's Avatar
Thumbs up
As a side note I have picked up these batteries for free. Look for them at Battery +. The one near me allows you to drop off dead batterys after hours behind the store. I have gotten 2 so far. I have had one for over 2 years now and the other just sits on the shelf.
06/12/04 ordered MK III roadster, 4.6 DOHC, T-45 5 spd, IRS, dual roll bars, Delivered 8/4/04, started 7-8-08, Back from paint 9-26-09, ****GRADUATED**** 6/14/10
FFR1004185RD
TD is offline
post #27 of 35 (permalink) Old 03-31-2015, 12:43 AM
Or... Just throw 100amps at it with an old school big amp charger. No need to fool anything. Just make sure an disconnect it when she gets warm.
mikeinatlanta is offline
post #28 of 35 (permalink) Old 03-31-2015, 01:33 AM
ryans88gt's Avatar
Had an optima red top for 2 years ~900cca. I had a slow crank, tried everything, increasing cable size, cleaning contacts, adding extra ground to the starter etc... finally it wouldn't crank anymore.
Put in a 500 cca spare autozone battery I had sitting in the garage for 3 years and the car cranked over faster than it ever did with the optima and continued to work well until I sold the car.
In my opinion, save your money and don't bother with the optimas.
In other news I have had 2 exide batteries fail in under a year, one on the roadster and one on my 52 pickup. Menards keeps taking them back and giving me new ones, they have a 40 month warranty. When I say fail I mean acid is pouring out and they have less than 10 volts.
ryans88gt is offline
post #29 of 35 (permalink) Old 03-31-2015, 02:09 AM
Cobra Colorist
j.miller's Avatar
Optima has come out with their own charger that will take them from near 0 to full charge......be that as it may....I have had both good (8 years) and bad (3 months) and then again, had good and bad luck with other brands. Everything is mass produced and shoved up the dark side of the moon these days.....They don't have to make quality products as long as they are willing to take their crap back when it fails and hand you a new one.....hell of a deal!!!!! Just one thing,,,,,I DON'T WANT TO SWAP BATTERIES, ALTS., WATER PUMPS, FUEL PUMPS, ETC FOR THE REST OF MY LIFE !!! I'M OLD, I'M TIRED AND CRANKY.......give me something that works and I'll gladly pay for it.....ONCE !.....holly bat crap ! I think you hit a nerve
j.miller is online now
post #30 of 35 (permalink) Old 03-31-2015, 02:26 AM
Administrator
Tell us how you REALLY feel !
