351w hood clearance - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 12 (permalink) Old 11-14-2009, 04:18 PM Thread Starter
BigLeo69's Avatar
Icon21 351w hood clearance
anyone using a Edlebrock RPM air-gap intake
and will it fit under the hood with the 4.30 front to 5.30 rear Ht.
been wieghing the idea of the air-gap
or performer 3.40 to 4.75 hts. . also the Weihand stealth is in the running.
what combo's with the air-cleaner (oval) type anyone use without clearance
problems.
"Torque is the grunt
MK3.1 #6945 her name is Buffy
p/u 04/04/09 roller 08/27/09
go-cart Memorial Day 2011
body on 11/11/11 Veterans Day
372w handbuilt
BigLeo69 is offline
post #2 of 12 (permalink) Old 11-14-2009, 05:35 PM
section 8
I've got a vic jr which I think is shorter than the air gap previously a 770 now efi Bob
FFR5020 MK III Whitby body +paint, sai mod, Tremec,408, Cobra/Oben brakes , Halibrands, mass flo , gas n pipes, levy rad team3 spinners.Fortes driveshaft, pulleys ,and quick release steering.. Previously Bob T****r
Bongo Bob is offline
post #3 of 12 (permalink) Old 11-14-2009, 09:25 PM
rscocca's Avatar
Vic Jr. intake on 351w block I have about two inches clearance to bottom of hood when closed. I used a 1.5 inch drop cleaner from summit.
CLASS OF 2009 # 79 FFR MK 3.1, # 6898, Complete kit arrived 02/07/09, roller 03/30/09, first start 07/14/09, Registered 10/14/09, PPG Orange Glow over Sterling silver, Dart aluminum 427W (445 rwhp), stack fuel injection,on board fire supression,Front Runner Serp system, TKO 600 mid shift mod, ISIS system, Hydroboost brakes with Willwood pedals, PS, A/C, IRS, Griggs racing front suspension, Foot box mods both sides,Dark Water splitter,dead pedal,glove box. (where's my publisher) Lots o Goodies
rscocca is offline
post #4 of 12 (permalink) Old 11-14-2009, 09:37 PM Thread Starter
BigLeo69's Avatar
Question still asking about the weihand and rpm air gap clearance
how tall is the vic jr?in relation to the rpm air gap?
and what off set on that air cleaner maybe even a part#
nice engine compartment and the color looks similar to the ffr that was in the backroom when i was there in April, what color is that? rscocca...
372w handbuilt
BigLeo69 is offline
post #5 of 12 (permalink) Old 11-14-2009, 09:46 PM
rscocca's Avatar
Bigleo69--
Here is a link to the cleaner. 1.25 inch drop.
http://www.summitracing.com/parts/KNN-66-3040/
The color is a PPG color Orange glow over sterling silver.
As for the height difference I'm not sure,
rscocca is offline
post #6 of 12 (permalink) Old 11-14-2009, 10:39 PM
I run an air-gap on a 351W with Energy Suspension poly engine mounts, a Speed Demon carb, and a 14-inch diameter, 3-inch thick K&N air filter with a 1 1/4 - inch drop base and a K&N filter top. Heads are AFR 185's with Fel Pro 1110-2 gaskets; intake gaskets are Fel Pro 1260's. With a Barry Grant gasket between the air cleaner and the carb (this is a fairly thick gasket of this type, maybe 1/4 inch), air cleaner-to-hood clearance is tight at the air cleaner top edges, but OK. No problems.
mrpatt1 is offline
post #7 of 12 (permalink) Old 11-15-2009, 12:16 AM
I have a Performer rpm manifold (not airgap) w/ a BG 650 speed demon and a 1/2 inch spacer and the usual Cobra oval air filter. haven't bothered to measure hood clearance but there is about 1/2 inch under the body edge ahead of the windshield.
CraigS is online now
post #8 of 12 (permalink) Old 11-15-2009, 12:44 PM Thread Starter
BigLeo69's Avatar
Thumbs up
thanks, for the info this helps.
getting ready to put my engine together in the next couple weeks.looking to do some porting on the intake and exhaust.
but off the subject, anyone know why some states have gear drives illegal
and what states those might be? hell i just read that on the install directions.
372w handbuilt
BigLeo69 is offline
post #9 of 12 (permalink) Old 11-15-2009, 05:28 PM
na
Send a message via AIM to hotmansweep
I have air gap,holley carb,2.5 inch round air cleaner,1 inch clearance
hotmansweep is offline
post #10 of 12 (permalink) Old 11-16-2009, 02:47 AM
Certified Mad Scientist
TXBLU's Avatar
What's the part number on the Energy Suspension poly engine mounts?
Thanks!
Eric
TXBLU is offline
post #11 of 12 (permalink) Old 11-16-2009, 04:34 AM
I run a 393ci Windsor with an Air Gap manifold, 770 Holley, 1-1/4" drop base Moroso 14" air cleaner - everything fits OK. The air filter element is about 2-3/4" tall. The drop base air cleaner is a necessity.
I wanted to run one of the oval Cobra air cleaners, but couldn't get it to clear the hood.
Ken
MkII (7/2004), 393ci, TFS TW Heads, AirGap, 770 Holley, TKO-600, Baer Brakes
Ken McGuffin is offline
post #12 of 12 (permalink) Old 11-23-2009, 04:26 PM
Where's my keys?
Orlandocobra's Avatar
"What's the part number on the Energy Suspension poly engine mounts?"
Looks like these are the 5.0 motor mount numbers. Not sure if they are for a 351w.
Motor Mount:
4.1122G GT 2WD Motor Mount; Black; Pair; Left (Driver); Right (Passenger) Side; 5.0 Liter
4.1122R GT 2WD Motor Mount; Red; Pair; Left (Driver); Right (Passenger) Side; 5.0 Liter
4.1122G LX 2WD Motor Mount; Black; Pair; Left (Driver); Right (Passenger) Side; 5.0 Liter
4.1122R LX 2WD Motor Mount; Red; Pair; Left (Driver); Right (Passenger) Side; 5.0 Liter
Orlandocobra is offline
