Panel corrosion - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 21 (permalink) Old 10-14-2009, 01:16 AM Thread Starter
Silverstreak02's Avatar
Panel corrosion
I noticed some corrosion on a few aluminum panels today. I'm able to remove it by scrubbing it with a scotch brite pad. Should I clean these up and have them powder coated or should I make new panels first? I'm concerned with the corrosion coming back.
Silverstreak02 is offline
post #2 of 21 (permalink) Old 10-14-2009, 01:20 AM
Stinson Pilot's Avatar
Looks like filiform corrosion.
Are those panels painted?
If they clean up without taking too much off (I mean 10-15% of the thickness), just prime & paint or powder coat.
Stinson Pilot is offline
post #3 of 21 (permalink) Old 10-14-2009, 11:12 AM
Agree with Doug. The natural course for Aluminum exposed to air and moisture is to slowly oxidize. It does so immediately after any abrasive or chemical cleaning process, but the oxide layer is extremely thin. With time, the oxide layer becomes thicker. Because of various factors, this process does not occur totally evenly, as is the case with your panels. This is why architectural aluminum (as in door and window frames) are always anodized or powder-coated. For most of us, all things considered, powder-coating is the best route to go for the FFR body panels.
HTH,
Bill Waters is offline
post #4 of 21 (permalink) Old 10-14-2009, 01:06 PM
Here is a thread where filiform corrosion was discussed. What you have is not normal for our aluminum panels. On the other thread it ended up being swimming pool chemical storage causing the problem.
mikeinatlanta is offline
post #5 of 21 (permalink) Old 10-14-2009, 02:06 PM
That looks exactly as mine do, although not to that extent. I have removed all my pool chemicals from the garage, but it still seems like the corrosion is continuing. I am still not totally convinced that the pool chemicals are the culprit.
I used a Scotch Brite pad (green) and removed the corrosion off of one small panel. It worked well, but will required a lot of work for all the panels.
I have not decided what I will do with the panels, as I really wanted the raw aluminum look in the engine bay. I do not feel the powder coating will give the same look.
Paul
MKIII, 427W, IRS, dual chrome roll bars, FFR lca\'s, heater kit, vintage gauges, and 17\" Bullitt Anthracites 255s Front 315s Rear . Kit delivered Oct 17, 2005.
Paul Adkins is offline
post #6 of 21 (permalink) Old 10-14-2009, 02:29 PM
If you don't get rid of the corrosion COMPLETELY, it will continue to be a problem.
When we have corrosion on airplanes, we have to make darn sure it's completely gone, even if this means taking major structural components apart to get to it.
Mike's thread he referenced above has lots of good info on corrosion.
post #7 of 21 (permalink) Old 10-14-2009, 02:49 PM
AC Bill's Avatar
Couldn't one simply paint over it with a spray bomb, (after careful masking, if on car) to stop the corrosion, and prevent future problems? Powder coating if the panels are already mounted seems like a major job, having to drill out rivets, cut through the silicone, etc..
Love at first bite! FFR6803RD, MKIII 3.1, 302EFI, fr/rr disc brakes, WC-T5 c/w Hurst Short Shifter, 3 link, Koni coil overs, dual roll bars, BBK 4-4 headers, 3.55 rear, BBK rr lower control arms, Chuck's Roadster wire harness, part donor, part new. Officially on road 09/2010
AC Bill is offline
post #8 of 21 (permalink) Old 10-14-2009, 05:22 PM
Lay posi
wibby's Avatar
Filiform corrosion can also be caused by electrolysis (electrolytic corrosion). I have filiform corrosion around the center of my aluminum Mazda 3 wheels due to the contact of dissimilar metals (steel hub against the aluminum wheel) along with high humidity (they get wet when it rains). In my case antisieze would have probably prevented it, but it's too late now.
Wibby
306, AFR 185 heads, Kenne Bell Supercharged, power steering, power brakes
wibby is offline
post #9 of 21 (permalink) Old 10-14-2009, 05:34 PM
Mike.Scheurich's Avatar
you could clean them up and have them powder coated with a clear satin. this would give you the brushed aluminum look with the protection you need.
just a thought
Mike S
Mike.Scheurich is offline
post #10 of 21 (permalink) Old 10-14-2009, 05:42 PM
Arch F's Avatar
Doug or other experts,
There are probably 1,000's of uncoated panels installed in these cars. Will this type of corrosion lead to something bad and if so over what time span?
Arch
Arch F is offline
post #11 of 21 (permalink) Old 10-14-2009, 06:02 PM
Arch, since this type of corrosion is pretty rare on unpainted, aluminum clad panels, I would think these particular panels were not treated properly from the manufacturer. Aluminum in this condition will normally oxidize, get that powdery white coating on them.
If left untreated, it will destroy the panels and eventually bleed over onto whatever material they happened to be attached to.
Untreated, they need some type of repetitive care, or just clear coat them if you like the aluminum panel look.
post #12 of 21 (permalink) Old 10-15-2009, 01:20 AM Thread Starter
I was able to remove it with some scotch brite and elbow grease. My panels aren't riveted yet so I'll remove them and get them powder coated. Thanks for all the suggestions.
post #13 of 21 (permalink) Old 10-15-2009, 03:28 AM
planning
a follow up question: will "most" of the roadster panels simply oxidize in an even manner, providing its own weatherproofing coating? I ask because I am planning on a daily driver (yes, here in the northeast!) and would like to avoid the cost of powdercoating everything. Coast of a winter hardtop already increasing costs by a bit! If the panels really will need some protection to last, what about truck bed liner? TIA
Michael
cobraboys is offline
post #14 of 21 (permalink) Old 10-15-2009, 03:37 AM
I painted mine with a rattle can Hammertone paint. Came out really nice. Easy touch up and the aluminum is protected.
If you paint, scuff it up good, prime and paint. Best bang for the buck.
post #15 of 21 (permalink) Old 10-15-2009, 03:54 AM
Big Sky Builder
beartoothweb's Avatar
I just did the paint on my firewall and my F panels after they were in the car (not by me). It was a total PITA. There are just too many nooks and crannies to be able to mask everything easily and apply color (hammertone in my case).
What about cleaning them up THEN applying some sort of clear over them? You'd have to be less concerned with the overspray, and it would still look like it does now.
Kevin Davis (KD)
FFR#6407
Home 4/18/09 - Roller 12/7/09 - First Start 1/23/11
First Drive After Finish - 8/1/15
What I do to pay for it all - Web and App Development
Professional Auto Detailing, Vacation Rentals, Little of Everything
beartoothweb is offline
post #16 of 21 (permalink) Old 10-15-2009, 06:43 PM
Gale K's Avatar
Another option that was (briefly) mentioned is anodization. I followed Larry Johnson's lead and had all of my panels clear anodized. Obviously, this would need to be done pre-installation, but it does give you protection from corrosion. If I'm gathering it right, SilverStreak has yet to install the panels, so it could still be done.
In the end, not a lot of aluminum is left showing (if you put carpet in), so asthetically, I didn't gain a whole bunch. But, they do look good. Engine bay stuff shows, trunk shows (unless you carpet it/sound proof it). Underneath shows when on a lift.
Just another option. And, I'm glad I did it at this point... ask me in a few years if my opinion is the same or not.
One of the last Mark II's, FFR complete date 5/8/04, delivery date 5/23/04, donor-'93 Mustang GT. Yes, that is me in my Avatar. :)
Drivin' the hell out of it in gelcoat!!!
Gale K is offline
post #17 of 21 (permalink) Old 10-15-2009, 06:52 PM
Be aware that you can't paint aluminum as if it was steel and have it last. Sheet aluminum is normally an alloy with pure aluminum clad to it. The pictures show filiform type corrosion IMHO. To be rid of it it must be mechanically removed, conversion treated with alodine, primed (preferably with zinc chromate) and painted. Powder coating or such of new uncorroded panels could work too.
A&PCobra is offline
post #18 of 21 (permalink) Old 10-16-2009, 05:19 PM
Fifty-Two's Avatar
Sharkhide is another option (after the panels are free of any corrosion of course). Much easier to apply than paint, and much cheaper than anodizing or clearcoating. Plus, it can be applied after the panels are on the car if needs be. I know "Greg M" and others have had good success with this route.
One of our vendors sell it, and the price is actually better than a couple other major suppliers: http://ffmetal.com/#sharkhide
- John
Mk 3.1 - FFR6671
FE Big-Block / Pin-Drive IRS / TKO 600 / Konis / Smiths Gauges / SC Dashboard / Vintage 15" Pin-Drives / Goodyear Billboards
Fabrication (the fun stuff): Stainless CSX-Style Throttle Pedal : AC Pedals on Modified Wilwood Arms : CSX-Style E-Brake Lever w/Custom Mounts & Linkages : Stainless CSX-Style Footbox Vents : CSX-Style Dash Support Tubes : CSX-Style F-Panels : Firewall Forward 4" : Trunk Storage Box : Aluminum Footbox Reinforcement Plates : Recessed Dash-Hoop : Stainless Brake Lines : "Full" Drop-Butt Mod : Driveshaft Loop : Recessed Rear Bulkhead & Exposed Rollbar ... hopefully the list continues!
"Trying" to recreate a Semi-Comp 427...
Fifty-Two is offline
post #19 of 21 (permalink) Old 10-20-2009, 12:55 AM Thread Starter
I went to the powder coaters today and showed him the corrosion and oxidation on the panels. He said it would be fine after he treated it. I have to remove all the panels, file the edges and deburr the holes. I hope to have them ready for next week. He said he could have them done in 2-3 days and would be around $10 a panel. I've decided to do all of them after seeing the corrosion.
post #20 of 21 (permalink) Old 10-20-2009, 10:18 PM
Silverstreak02,
Did the powder coater recommend removing the corrosion before they coat the panels?
Paul
post #21 of 21 (permalink) Old 10-21-2009, 12:41 AM Thread Starter
Originally Posted by Paul Adkins View Post
Silverstreak02,
Paul
The Powder coater said they would do it and etch the panels immediately before they coat them. I think I'll remove it before I drop them off just to be sure. I won't be able to drop them off on Monday as planned since I'll be spending my time removing the supercharger from the Miata instead. Do you know anyone that wants to buy a complete system for a Miata?
