My spark plugs are saturated with gas...Anybody? - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 8 (permalink) Old 02-23-2009, 02:32 PM Thread Starter
Eric B's Avatar
O.K.,
Here's the deal,
Over the past few months I've been trying to figure this thing out.
After running my car a few times it eventually doesn't want to start,it just turns over.
After I replace the plugs it starts right up.
When I pull the plugs they (all of them) are completely saturated with fuel,I believe this is why I run into my starting problem.
I have changed my fuel pressure regulator to a factory OEM one.
My engine is a 302 with Trick flow aluminum heads and Trick flow EFI.
I was told I have have 30lb injectors.
It also has a pretty lumpy cam.
I don't know the exact specs. of the engine as I did not build it myself ,it came out of the donor.
Can anybody recommend or advise what could be causing it to run so rich ?, I'm getting tired of changing the plugs....
Eric
Eric B.
**** INITIAL SUCCESS OR TOTAL FAILURE ****
93 Notch donor,302 Trick Flow intake & heads/17"Rivet Bullit rims 10.5 + 9's w sumi's/3 link/Tubular LCA/ picked up donor 12/2006.Ordered kit 08/30/07.picked up kit11/03/07.Its a roller on 11/25/07.Engine in 12/29/07.First Start 07/03/08.First Go-Kart 10/09/08.Off to the NYSDMV bar exam Sept 9th, 2009. Planned Completion target date June 30,2015(retirement date).Certified Graduation date on Sept 20,2009.
Eric B is offline
post #2 of 8 (permalink) Old 02-23-2009, 03:12 PM
I would start by checking and adjusting the basic engine tune.
Timeing,tps voltage. Ohm the plug wires to be sure thier good.
Also put a gauge on the fuel rail to verify fp. Just useing a new regulator does'nt guarentee it's correct. Should have 39psi at idle vacum disconnected
M III recieved 8-06, 3 link,lca's PS+PB,carb,302,373 gears, T5 first start 8/27/06.Go Kart 9/9/06
Tagged 10/24/06
Graduate 4-07
hind sight is offline
post #3 of 8 (permalink) Old 02-23-2009, 04:43 PM
narve00's Avatar
Do you have a MAF calibrated for the 30# injectors?
If the engine is not getting warm and going into Closed Loop and then keeping power to the EEC, you will struggle using the 30's. The base tune is going to be pretty rich until it learns to cut back the fuel. The EEC will revert to the base tune anytime it loses power.
narve00 is offline
post #4 of 8 (permalink) Old 02-23-2009, 04:57 PM
Forte's Parts Connection
snakeboost's Avatar
Are you running a maf? Is it calibrated for 30lb in?
Paht time pahts guy!!!!!!!!!!
Your Solution Specialist!
Call 508-875-0016 to order today
snakeboost is offline
post #5 of 8 (permalink) Old 02-23-2009, 07:09 PM Thread Starter
Eric B's Avatar
I may have to bring it to a shop to get the MAF calibrated,and I will add an adj. FPR It originally had one but it was leaking so I just put a factory one in.
Eric B.
Eric B is offline
post #6 of 8 (permalink) Old 02-24-2009, 12:49 AM
section 8
yeah maf , has to be calibrated to the injectors . Also check for codes and vacuum leaks EFI is backward lean is rich . 1 other possibility is the map sensor , if its hosed it'll flood the engine . Can be tested with a voltmeter and a hand held vacuum pump. Bob
FFR5020 MK III Whitby body +paint, sai mod, Tremec,408, Cobra/Oben brakes , Halibrands, mass flo , gas n pipes, levy rad team3 spinners.Fortes driveshaft, pulleys ,and quick release steering.. Previously Bob T****r
Bongo Bob is offline
post #7 of 8 (permalink) Old 02-24-2009, 02:46 AM
Moderator Ad Nauseum
NAGA's Avatar
Just for grins, let's get to Narve's point. What temp thermostat are you running?
Yeah, it shouldn't make a difference. Even in closed loop where it's depending on its internal program and not yet using the HEGOs, it shouldn't be so rich it's fouling the plugs.
But still, what thermostat? And where's your temp sensor? Not your gauge sender. The temp sensor that goes to the computer.
d
Donald Rogus
NAGA is offline
post #8 of 8 (permalink) Old 02-24-2009, 04:29 PM
narve00's Avatar
When the HEGOs are inactive the EEC is in Open Loop (no feedback).
During crank the EEC is using 19 lb settings (no MAF input), so it blows in too much fuel at a 30/19 ratio. If the engine doesn't light off pretty quickly it starts to get flooded. Most guys who have run 42's without a chip have a routine of crank, if it doesn't start, stop, floor it (shut down the injectors) and try again.
Don's right the MAF will correct for the injectors (typing quick at work). However, seems most calibrated MAFs are weakest at idle (maybe less resolution at idle). The calibrated MAFs need some learning. It will never learn different crank settings.
If your MAF is not calibrated, it will absolutely be too rich.
narve00 is offline
