Traction Lok vs Limited Slip Diff
3.1K views 9 replies 7 participants last post by  Five Star Rep Max
#1 ·
What do most use?
Which is better for street use?
What is involved in switching from Limited Slip clutch to clutchless gears?
#2 ·
Traction Lok is the Ford trade name for its limited slip differential. Posi-Traction is the trade name General Motors thought up. Perhaps you're thinking of the difference between a "locker" style diff and a limited slip. With light cars, lockers can tend to make the car understeer while accelerating out of corners.
As far as clutch-style vs. gear-style limited slip diffs, the big differences are price (clutch-styles are cheaper), maintenance (clutch-styles require more periodic maintenance), and consistency of action (gear-styles don't diminish in performance over time like clutch-styles).
Hope that helps.
Eric
#4 ·
Relatively speaking it's easy. you keep track of the shims as they come out. Swap the ring gear over to the new center section and try to reassemble using the same shims in the same place.You need to get preload and ring gear backlash correct so there may be a lot of trial and error.You need a magnetic base dial indicator and some extra shims and then just some time on your back.Good luck
#6 ·
My 3.1 kit was supposed to come with the Tru-Trac set-up. This was the new type of third member being provided last fall. After waiting several months on the backordered rear end FF called and offered the old sytle limited slip rear end which I took advantage of.
From threads on installing the axles there is a major difference in the internal look of the third members. There was some confusion in the posts late last fall as many members had not seen the new Tru-Trac setup.
The original question posted was the difference between the two and which one was the best. That I don't have the answer to. After talking to the FF tech guys they didn't feel there was any major differences so I felt comfortable going with the older style unit.
#7 ·
rear end
No
just remove the center section. The nine inch you remove from the front, the 8.8 removes from the back. Buy a book that tells you how to do it or a lot of car mags have done articles on how to rebuild a rear end. If you don't do it right it may cause problems later.
Dwight
