What happens if you overfill coolant? - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 8 (permalink) Old 11-27-2008, 08:22 PM Thread Starter
I know what happens if you overfill oil, but what about coolant? Will it start blowing out of your engine, or will it just flow into (and then out to the ground) of your puke tank?
EFNFAST is offline
post #2 of 8 (permalink) Old 11-27-2008, 08:34 PM
Darren T's Avatar
Fill it completely full. Fill the overflow bottle about a 1/3 full.
SOLD - FFR5596RD MKIII. Recv'd 7/06 completed 6/08.
Levy Racing Stage 5 408w, MassFlo, I^2, IRS, Levy Konis, 17" FR500, Wilwood brakes.
Darren T is offline
post #3 of 8 (permalink) Old 11-27-2008, 08:35 PM
na
Send a message via AIM to hotmansweep
get some rags! hows the weather up in calgary
hotmansweep is offline
post #4 of 8 (permalink) Old 11-27-2008, 08:36 PM Thread Starter
Okay
Cold, but no snow yet, so I can't complain
EFNFAST is offline
post #5 of 8 (permalink) Old 11-27-2008, 10:31 PM
Alex,
One thing to be careful of...pets.
If you have a dog or cat, they just love the taste of this stuff.
If you spill it on the ground, and they lap it up, they're in trouble.
It only takes a very small amount to kill them.
Mark III. 347 Stroker, Holley 650, Edelbrock heads, first start November 16, 2008
obrienj is offline
post #6 of 8 (permalink) Old 11-28-2008, 01:05 AM
Gregg427's Avatar
When I did my first start I filled it to the top and then filled about 1/3 of the overfill as has been suggested. I ran over as the fluid heated and expanded. It may take a time or two until you get it right so the overflow doesn't overflow.
As John noted ethylene glycol (anti-freeze) is very sweet smelling to pets. They will run to it and lap it up. It only takes one or two laps to kill by shutting down their kidney's.
Gregg
429 bored .040" over, Edelbrock Torker II and 800 cfm carb, 531HP, 517 ft-lbs, TKO 600, Koni coil overs, Sumi HTPZ III 255/40/18 and 285/35/18, Father/Son project dedicated to "Pop Pop". On the road May 2009.
Gregg427 is offline
post #7 of 8 (permalink) Old 11-28-2008, 10:22 PM
Very sound advice. I came real close to losing a dog to coolant...costly vet bills...he should have died but thankfully they saved him.
Originally Posted by obrienj View Post
Alex,
JAM
JAM1775 is offline
post #8 of 8 (permalink) Old 11-29-2008, 03:40 AM
Moderator Ad Nauseum
NAGA's Avatar
To answer your original question, it won't hurt the engine or anything else (other than the aforementioned pets) if you happen to overfill. It'll just puke out your overflow tank as it expands from heating.
Just because it pukes however, it doesn't necessarily mean it's overfull. The same symptom can also indicate it's not full enough.
If you have air bubbles, that can also make it puke, as the water flashes into steam and really expands (know how steam engines work?).
d
Donald Rogus
NAGA is offline
