Driveshaft Safety Loop - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 16 (permalink) Old 09-11-2008, 01:18 AM Thread Starter
New Member
clays123's Avatar
What is the best way to install the driveshaft safety loop? Should I use longer bolts and thread them right through the 4'' frame or use the shorter bolts and just tap into the 4"?
How do you guys do yours? Pictures would be helpful.
Clay
clays123 is offline
post #2 of 16 (permalink) Old 09-11-2008, 01:54 AM
There are lots of opinions. I threaded mine into the top of the 4" tubes as I am not a welder kind of person.
I believe it will hold in place in case of a catistrophic failure one time - that is what it would be needed for...
StephenP is offline
post #3 of 16 (permalink) Old 09-11-2008, 01:55 AM
Dark Side
ZanexGt's Avatar
Send a message via AIM to ZanexGt
Not meant to be a threadjack but ....
Has anyone received benefit from the safety loop directly on a FFR?
If the U joints on the driveshaft go, that driveshaft is Awfully close to the pelvis! I am thinking about installing one of these and just looking for opinions. I too am interested how you all installed your safety loops.
-Robert
FFR #6785 MK3.1 Complete Kit
Ordered: 08-27-08
Delivered: 10-19-08
Roller: 07-20-10
ZanexGt is offline
post #4 of 16 (permalink) Old 09-11-2008, 02:10 AM
One of the local guys had a U joint let go in his car. It chewed up the tranny tunnel pretty bad. Very lucky it was at low speed and very lucky that nobody was hurt.
Kind of started the trend locally that every car I know details on does have a loop.
StephenP is offline
post #5 of 16 (permalink) Old 09-11-2008, 12:47 PM
Purple Venom's Avatar
Here's another thread with a few photo's and ideas on this:
Driveshaft safety loops?
Purple Venom is offline
post #6 of 16 (permalink) Old 09-11-2008, 01:30 PM
dug
dug's Avatar
this link shows Mustang Man's loop. I plan to use it on my build.
Bolt-In Driveshaft Safety Loop Found
dug is offline
post #7 of 16 (permalink) Old 09-11-2008, 05:43 PM
canuck1's Avatar
You might want to check with Mustang Man. I think he discarded that idea for his car(?). If I recall it did not provide enough clearance for driveshaft movement once he finally had all the parts together to check it.
It would probably work fine in an IRS car.
Sean
MK 3.5 (MK IV body retrofit to MK III chassis) 351W stroked & poked to 396 c.i., custom EFI, 4 into 4's, 3link, 3.73, 15" Halibrand replicas, SAI mod, full bumpers, 2 X roll bars, IČ electronics, hydroboost, 5-lug, GT front, MK VIII/Cobra rear discs, painted by SRP (again!)
canuck1 is online now
post #8 of 16 (permalink) Old 09-11-2008, 05:47 PM
I went through the 4" and weled any spot I could. Yes over-kill on this one as I have seen pictures of one that came through the cock-pit aluminum. If there was a passenger, they'd be missing a lrg today. I bought it from Summitracing.com
-Kouros
1920 is offline
post #9 of 16 (permalink) Old 09-11-2008, 06:08 PM
Brian F's Avatar
I bought a universal loop from JEGS and welded it to the underside of the frame tubes.
Non-Donor MKIII Delivered Oct. 18, 2005
Complete June 21, 2006
351w 400hp, T5, 3-link, 3:55
Brian F is offline
post #10 of 16 (permalink) Old 09-12-2008, 06:50 PM Thread Starter
New Member
clays123's Avatar
Thanks very much guys, you all have been most helpful.
Clayton
clays123 is offline
post #11 of 16 (permalink) Old 09-12-2008, 10:52 PM
Daily Driver since 2/03
When I was considering this, I thought that I should put in 2 loops. One for the front and one for the back. The shaft seems too short for just one loop to do much good. If you put just 1 loop in the middle, it seems that it could still thrash around quite a bit.
Has anyone put 1 loop in the middle and checked where the shaft could go if something gave way (both front and back, u-joints, bolts, flange, and sleeve)?
blue/white, 302 w/mass-flo, 3.55 gears, 2 roll bars, PS Eng wheels, 275/40 zr 17, 245/45 zr 17, Ipod & cruise control on the tranny tunnel
dwheeler is offline
post #12 of 16 (permalink) Old 09-13-2008, 12:46 PM
5.8Cobra's Avatar
I believe in the NHRA rulebook it says to place the loop 6" behind the front U joint. That would put our loop at the pinion flange since the actual tube is only about 4" long! I would say right in the middle would be fine. Its more for driver/passenger safety rather than keeping the car from catapulting when the driveshaft hits the ground! Anywhere you put it will be better than not having one at all! HTH
FFR 3107 Built & Sold
FFR 1990 Built & Sold
FFR 7330 Built & Sold
5.8Cobra is online now
post #13 of 16 (permalink) Old 09-13-2008, 01:44 PM
dv/dt's Avatar
That's what I did and for that reason.
More pics and info here:
Driveshaft Hoop System - DRAWINGS ADDED 1
Cheers, Rod
"Can you imagine?!"
dv/dt is online now
post #14 of 16 (permalink) Old 09-13-2008, 03:28 PM
Junior
03SC's Avatar
I think there might be a market for those Rod.
FF6854 - Completed 7/12/12 SOLD 8/28/2012
Levy 5-link, Levy Billet LCA's, Willwood 6/4's, Levy DA Konis, SAI mod
LR narrowed 8.8, Comp Bumpsteer. Stage 5.5 408W, Super Alloy T-5+, Ron Davis Cooling System, LR Custom Headers and Sidepipes. Performance Automotive Paint.
Build pics below:
03SC is offline
post #15 of 16 (permalink) Old 09-13-2008, 03:56 PM
Mustang Man's Avatar
Sorry I'm late to the party here, but yes, the loop provided with the TCP Mustang kit is too small and would touch the DS on full articulation. I also was planning to install from the top, which would not work with some that do not have a removable trans tunnel. I still have the parts and might try to figure something out in my "ample spare time" but I'm hoping the guys at Metco Motorsports (the ones building the Shelby GT500 5.4 modular Mk III) will come up with something since they have a full line of bolt in loops for classic and late-model Mustangs...
FFR5310RD
Mustang Man is offline
post #16 of 16 (permalink) Old 09-13-2008, 04:19 PM
NBWW's Avatar
Tapping the 4" tube will only make you feel good. It is only .125" thick. For that to be proper, it should be as thick as the diameter of the bolt used.
I also would not bolt through the tube as it could compress when tightened.
That only leaves welding tabs for attaching brackets in my opinion.
NBWW is offline
