Fuel Cell - FFCars.com : Factory Five Racing Discussion Forum
Go Back   FFCars.com : Factory Five Racing Discussion Forum > Off Topic > Smyth Performance G3F
Old 08-05-2012, 11:27 PM   #1 (permalink)
Starship Trooper
Bill Shaw's Avatar
Fuel Cell
Just a heads-up to the builders here...
The fuel cell supports supplied by Mark are insufficient. The fuel cell needs to be fully supported across the bottom, and the flimsy little bent pieces of tin and pop rivets will not be enough. The fuel cell will weigh near a couple hundred pounds when full, and shock loads on bumps will be much higher. Try standing on those flimsy little pieces that come with the kit and see what happens!
I replaced them with some more substantial angle iron, and welded them in place. I also used 4 sections of the rear door gasket under the cell, and 8 - 8" long self-adhesive rubber strips vertically in the corners.
My battery box straps hit the fuel cell on the top rearward edge so I used some more rubber cushion there.
'13 Smyth GF VRT - http://b.shaw.home.comcast.net/g3f
'10 Camaro SS - Daily Driver
'09 FFR Daytona Coupe - http://b.shaw.home.comcast.net/Daytona - Sold
Bill Shaw is offline   Reply With Quote
Old 08-06-2012, 10:16 AM   #2 (permalink)
Cone Killer
RedJoker's Avatar
Interesting, mine didn't have any sheet metal. It had the tabs where I bolted aluminum angle. Must have been a design change along the way. Having said that, I'll definitely take a look at that again. One of the things I was going to add to mine was a top bar. There is nothing to keep the fuel tank from sliding up and down. Yeah, it's not likely to happen but I think I want my fuel tank bolted in all directions.
RedJoker
G3F Build Blog: http://g3f-redjoker.blogspot.com/
RedJoker is offline   Reply With Quote
Old 08-11-2012, 03:28 PM   #3 (permalink)
G3F#24's Avatar
Fuel Tank
Hey Clint: I had the same fear about the tank "rising". I turned the top angle inward for containment.
Hey Bill: We didn't like the mounting either, and our interference was on the driver side, so we fabricated a 1/8" Stainless bracket for the driver side. The passenger side has a much shallower angle, but the driver side bracket is not as stout, and doesn't need the angle. We made the bracket 90 degrees.
G3F#24 is offline   Reply With Quote
