Motor Mounts upgrade needed? - FFCars.com : Factory Five Racing Discussion Forum
Go Back   FFCars.com : Factory Five Racing Discussion Forum > Off Topic > Smyth Performance G3F
Old 06-10-2011, 07:30 PM   #1 (permalink)
John Phillips's Avatar
One thing I noticed when taking out my engine: the motor mounts seem to be as flexible as jello! Once I'd removed the dogbone mount under the engine, it swung easily back and forth . I'm used to the poly mounts commonly used on the Factory Five Roadsters and a bunch of older cars I've worked on. Does the TDI have soft mounts because of diesel characteristics, or are my mounts likely shot from 220K miles of use? Main Q: do we want to mount this engine/tranny more solidly? Is that a potentially BAD thing? Thanks for any thoughts.
John Phillips, Jupiter, Florida
#1152; #3422; #1004554 mod 5.0 DOHC, IRS New Build and track pics here: http://imageevent.com/jlphil/carstuff/ffrmarkiiibuild
Smyth G3F Beta-build: 1999.5 Jetta TDI donor, Malone Stage 2 Tune and injectors. Love my Roadster; the G3F will be my daily driver. Build details here:http://www.g3f-jlphil.blogspot.com/
John Phillips is offline   Reply With Quote
Old 06-10-2011, 07:34 PM   #2 (permalink)
John, I'm going to guess "both." Your OEM units might be original, and are probably worn out. But diesels do tend to vibrate a lot more than gasoline engines, so I'd think pretty long before I went to a hard-mount or even a poly solution. You might consider replacing them with new versions of the same parts as well.
Isolating the engine from the chassis will make for a much-improved daily ride and drive experience, but at the expense of some rubber wear parts. Some manufacturers are even using oil-filled isolators these days... My FFR Roadster has the V12 hard-bolted direct to the chassis engine mounts, but I wouldn't even consider that (or anything close) for the G3F. Just my $.02, no charge!
Cheers, John
dukegrad98 is offline   Reply With Quote
Old 06-10-2011, 09:47 PM   #3 (permalink)
ixlr8's Avatar
Duke John has it correct. Your old mounts are a bit trashed, poly ones are available. But most folks I know who have put them in pull them back out as too much vibration makes it into the chassis. I would buy new OEM.
Present toys;
2005 GMC Sierra 1500
2002 VW TDI Golf- 251K miles- 56mpg- 135 hp/245 ft-lbs, VNT-17, PP520 nozzles, RC3+ tune (which sucks, looking for better tune).
2001 BMW R1100RT
1967 P400- Restoration to start in spring
1919 Harley Davidson- Retirement project
Future toys;
2001 VW TDI Jetta- 238K miles- stock.. for now. ---> 2011 G3F ---> maybe 2012 G3F, Beta #14-->#2-->#5-->To be sold!
ixlr8 is offline   Reply With Quote
Old 06-11-2011, 02:09 AM   #4 (permalink)
Played with the mounts a bit tonight, they are officially mush. Will order some OEM replacements, most cost-effective and least risky approach. Thanks for the ideas, guys
