Bill's G3F Build - Page 3 - FFCars.com : Factory Five Racing Discussion Forum
Go Back   FFCars.com : Factory Five Racing Discussion Forum > Off Topic > Smyth Performance G3F
Old 07-23-2012, 02:20 AM   #61 (permalink)
Starship Trooper
Bill Shaw's Avatar
Front suspension & brakes are done. Audi TT spindles, ball joints, A-arms, and calipers, Hawk HPS pads, Jetta tie rods & brake hoses, all new OEM bolts, nuts and bushings.
I need to get this thing moving, my brand new rotors are starting to show rust!
'13 Smyth GF VRT - http://b.shaw.home.comcast.net/g3f
'09 FFR Daytona Coupe - http://b.shaw.home.comcast.net/Daytona - Sold and greatly missed!
Bill Shaw is offline   Reply With Quote
Old 07-26-2012, 02:29 AM   #62 (permalink)
Starship Trooper
Bill Shaw's Avatar
Today's lesson learned - the rear sway bar has to go on before the rear K member, there's just no room for it to go in after. Side room may be an issue too. I need to pull the springs off and check the full range of travel.
Anybody else planning on front & rear sway bars?
Old 08-05-2012, 11:16 PM   #63 (permalink)
Starship Trooper
Bill Shaw's Avatar
The fuel cell is in.
Old 08-06-2012, 01:00 AM   #64 (permalink)
John Phillips's Avatar
Sweet! Glad to see forward progress...and signs of life on this board! Parts are on the way, I think, so maybe more action here soon!
John Phillips, Jupiter, Florida
#1152; #3422; #1004554 mod 5.0 DOHC, IRS New Build and track pics here: http://imageevent.com/jlphil/carstuff/ffrmarkiiibuild
Smyth G3F Beta-build: 1999.5 Jetta TDI donor, Malone Stage 2 Tune and injectors. Love my Roadster; the G3F will be my daily driver. Build details here:http://www.g3f-jlphil.blogspot.com/
John Phillips is offline   Reply With Quote
Old 08-15-2012, 02:15 AM   #65 (permalink)
Starship Trooper
Bill Shaw's Avatar
Got brakes bled tonight. It doesn't run but it can stop! Even more important, I can torque the axle nuts now.
Old 08-20-2012, 02:34 PM   #66 (permalink)
Starship Trooper
Bill Shaw's Avatar
I moved the GF out of the garage yesterday so I could use the lift for another car, and I shot a 360 sequence around it while I was at it. Check it out...
360 degrees around Bill's GF
Old 08-25-2012, 03:21 AM   #67 (permalink)
Starship Trooper
Bill Shaw's Avatar
Cleaned the garage and started assembling the engine this week. So far everything looks good.
Old 08-25-2012, 04:50 PM   #68 (permalink)
Guys,
I couldn't help but notice the fuel cell. What are the dimensions ? I might have that exact cell sitting here at home. It is brand new. I don't know if Mark includes it or not but I would sell it pretty cheap.
Olli
FFR Roadster #2316 sold
FFR Hot Rod '33 #003
Olli is offline   Reply With Quote
Old 08-26-2012, 11:55 PM   #69 (permalink)
Starship Trooper
Bill Shaw's Avatar
Fuel cell is included, Olli.
I worked a bit more on the engine assembly today.
Found the upper chain lower sprocket is chewed up, and can't find my spares. I need to find a replacement.
Old 08-28-2012, 03:48 PM   #70 (permalink)
4229GL's Avatar
is the color anything special on the block? significance or something? It looks nice.
...FFR1668's pesky kid
4229GL is offline   Reply With Quote
Old 08-28-2012, 03:53 PM   #71 (permalink)
It's a Ford block!
Cheers, John
dukegrad98 is offline   Reply With Quote
Old 08-28-2012, 05:11 PM   #72 (permalink)
Starship Trooper
Bill Shaw's Avatar
The color is indicative of the fact that I am sick of black - so far everything on the car is black, very little detail shows in the pics because it is all black.
(I also had 1/2 pint of POR15 engine paint left over from the Coupe build, so you're close, John! :-) )
Old 08-29-2012, 02:32 AM   #73 (permalink)
Starship Trooper
Bill Shaw's Avatar
Upper chain lower sprocket
I found my missing sprocket! Just in time, I was about to go buy one. It was in the little red compartment box under the grey roll-around bench. I must have 2 hours into looking for it, does that count as 'build time'? :-)
Old 09-01-2012, 04:22 AM   #74 (permalink)
Starship Trooper
Bill Shaw's Avatar
Almost an engine
I almost have an engine again!
Old 09-03-2012, 02:40 AM   #75 (permalink)
Starship Trooper
Bill Shaw's Avatar
Just sayin...
Old 09-03-2012, 05:40 PM   #76 (permalink)
Starship Trooper
Bill Shaw's Avatar
I'm on hold with the engine waiting for a rear main seal, so I started working on electrical. Here's what I've come up with so far...
Here's where I decided to mount the power distribution box. It needs 2 wires extended to the plug on the distrib box, and a large gauge wire to the alternator/starter.
Note I've also decided to mount the charcoal canister up here. It's near the tank (where VW intended it), and I need the space Michael chose to mount my coolers. It mounts to the bottom and top horizontal fuel cell braces, I need to build the top bracket for it still.
Here's the driver's side of the front end wiring harness. I stripped the harness wrap to move the distribution box, yuk what a gooey mess! PB Blaster does a good job of removing the goo. I circled 2 connectors that need to be extended, one to the dist box, and the other to the engine harness out back. Did you guys need to extend this one to the engine harnesss, too?
It will all be wrapped up again in harness wrap and mounted properly before I'm done, of course.
Old 09-13-2012, 02:17 AM   #77 (permalink)
Starship Trooper
Bill Shaw's Avatar
Been down for 5 days because the filter on the telephone pole died. No internet gave me time to update, so major updates are in the engine and gocart sections of my GF pages.
Old 09-15-2012, 02:58 AM   #78 (permalink)
Starship Trooper
Bill Shaw's Avatar
In keeping with the recycling theme, the upper evap canister bracket was recycled from one of the dash brackets. It'll get cut along the line.
Old 09-15-2012, 11:37 AM   #79 (permalink)
Sweet, I was trying to think of a way to use those dash brackets!
Old 09-15-2012, 03:02 PM   #80 (permalink)
Cone Killer
RedJoker's Avatar
Just out of curiousity, how are you running your coolant lines? Most everyone is sending them right through where you are mounting the canister. I'm not saying your wrong because I want to see alternatives.
RedJoker
G3F Build Blog: http://g3f-redjoker.blogspot.com/
RedJoker is offline   Reply With Quote
Old 09-15-2012, 10:14 PM   #81 (permalink)
Starship Trooper
Bill Shaw's Avatar
I didn't get that far yet.
Old 09-30-2012, 03:51 AM   #82 (permalink)
Starship Trooper
Bill Shaw's Avatar
The new radiator is in and the fuel lines are run to the rear.
The coolant lines are going to the drivers' side down and around the fuel cell to the tunnel. I bought another upper radiator flange to use on the bottom to point it straight back instead of angling over.
Old 09-30-2012, 04:41 PM   #83 (permalink)
Sanitary fuel lines! Can't wait to see how the coolant lines run.
Old 10-04-2012, 02:23 AM   #84 (permalink)
Starship Trooper
Bill Shaw's Avatar
More porn
Old 10-04-2012, 07:57 PM   #85 (permalink)
D2W
Rookie
D2W's Avatar
Bill I can't remember what you are using for the turbo kit. Ebay cheap stuff like Mark has planned or the domestic good stuff?
As I always tell my boss,\"I can do anything with enough time and money.\"
D2W is offline   Reply With Quote
Old 10-05-2012, 01:17 AM   #86 (permalink)
Starship Trooper
Bill Shaw's Avatar
Actually, you can sort of see it in the pic above in the bottom right corner - PTE - Precision Turbo Engineering (5857SP).
Ceramic ball bearings, billet turbine (above), surge suppressing housing.
I am amazed at the milling in that turbine.
Old 10-05-2012, 01:26 AM   #87 (permalink)
Starship Trooper
Bill Shaw's Avatar
The fuel pump mounts almost where the original was, so the fuel pump is already wired, just need to crimp some terminals.
I know, the -8 hose is way overkill, but I had some -8 connectors. It's dropping down to -6 from here to the rail.
Old 10-05-2012, 04:42 PM   #88 (permalink)
D2W
Rookie
D2W's Avatar
Bill your build is just incredible, way to go all out. Are you planning any body mods to spice it up? I found the final design to be kinda bland.
Old 10-06-2012, 01:24 AM   #89 (permalink)
Starship Trooper
Bill Shaw's Avatar
Yes
Old 10-06-2012, 03:46 AM   #90 (permalink)
Starship Trooper
Bill Shaw's Avatar
If I have it right, on the the block the oil comes out of the center hole and returns to the outer ring, is that correct?
Need to figure out which is in and which is out
LinkBacks (?)
LinkBack to this Thread: http://www.ffcars.com/forums/139-smyth-performance-g3f/264919-bills-g3f-build.html
Posted By For Type Date
Bill's G3F Build - Page 3 - FFCars.com : Factory Five Racing Discussion Forum This thread Refback 10-01-2012 01:18 AM
Bill's G3F Build - Page 3 - FFCars.com : Factory Five Racing Discussion Forum This thread Refback 10-01-2012 01:11 AM
