RedJoker's G3F Build - Page 4 - FFCars.com : Factory Five Racing Discussion Forum
Go Back   FFCars.com : Factory Five Racing Discussion Forum > Off Topic > Smyth Performance G3F
Old 09-03-2012, 02:00 PM   #91 (permalink)
Starship Trooper
Bill Shaw's Avatar
Thanks for the pics, Clint. I'm kind of surprised at the number of pink butt splices I see.
'13 Smyth GF VRT - http://b.shaw.home.comcast.net/g3f
'10 Camaro SS - Daily Driver
'09 FFR Daytona Coupe - http://b.shaw.home.comcast.net/Daytona - Sold
Bill Shaw is online now   Reply With Quote
Old 09-03-2012, 02:49 PM   #92 (permalink)
Cone Killer
RedJoker's Avatar
I think the idea is that the novice builder would be more comfortable with those splices. I'll be honest, I am WAY more comfortable soldering than using those connectors. That's just my opinion, of course. Others can argue the relative merits.
RedJoker
G3F Build Blog: http://g3f-redjoker.blogspot.com/
RedJoker is online now   Reply With Quote
Old 09-24-2012, 11:31 AM   #93 (permalink)
Starship Trooper
Bill Shaw's Avatar
Keep trimming the dash area until those gaps you have go away. I had the same problem at first, more trimming fixed it.
Old 09-24-2012, 11:59 AM   #94 (permalink)
Cone Killer
RedJoker's Avatar
I'll keep looking at it but the issue I have is front to back. With the three bolts on each side finger tight, the vertical tabs on the front are a good inch back from the strut tower. Its not obvious that more cutting is the answer but I'll keep looking. Thanks!
RedJoker
Old 09-24-2012, 12:59 PM   #95 (permalink)
John Phillips's Avatar
Clint, great progress! Love the blog entry, and the water pipe tunnel work. Man, if I ever get to build another G3F, I'm definitely looking for a white donor...makes it easy to see what you're doing down there.
My windshield frame vertical front tab worked out on the passenger side perfect, but there was about a 1/4"-3/8" space on the driver side between the tab and the strut tower wall. I used washers under it to make a solid connection. If there's an inch of space on yours, I don't have much advice for ya!
Mark's planning a roadtrip with the G3F mule this coming weekend. Should be some good feedback after that.
John Phillips, Jupiter, Florida
#1152; #3422; #1004554 mod 5.0 DOHC, IRS now for sale, pics at http://imageevent.com/jlphil/carstuff/ffr
Smyth G3F Beta-build: 1999.5 Jetta TDI donor, Malone Stage 2 Tune and injectors. Love my Roadster; the G3F will be my daily driver. Build details here:http://www.g3f-jlphil.blogspot.com/
John Phillips is online now   Reply With Quote
Old 09-24-2012, 04:09 PM   #96 (permalink)
Cone Killer
RedJoker's Avatar
I talked with Mark and he told me to just smack the tabs with a hammer until I get them close, use spacers or not even use them at all. It's really the three bolts on each side that are doing all the work and the alignment. Good to know!
RedJoker
Old 09-25-2012, 12:39 AM   #97 (permalink)
Starship Trooper
Bill Shaw's Avatar
I had a good amount of space there first time I tried to fit the windshield. If the windshield was built correctly it HAS to fit, your car is not different from all the others. One more thing to think about - if you shim it you may have trouble getting the hard top to fit right because your windshield angle is not exactly right.
You, too, JP - if you shimmed your windshield it probably is not on straight!
Look it all over closely and break out the 4 1/2" grinder again! :-)
Old 09-25-2012, 01:48 AM   #98 (permalink)
Cone Killer
RedJoker's Avatar
So I followed your advice and got one side to fit as it should. The other side still does not but I'm not convinced its my cutting. When I make measurements, they are coming out different on each side. I didn't get to spend much time on it this evening but I'm wondering if there isn't an issue with the windscreen.
I'll report back in the next few days when (if?) if I figure it out.
RedJoker
Old 09-25-2012, 12:59 PM   #99 (permalink)
manual_tranny's Avatar
These windshield subframes are one of the most difficult parts of the G3F to install. I do believe that your frame is straight though, because we weld the windshield subframe to pieces that are actually bolted to a cut apart MKIV chassis. We also test fit most of the windshield frames.
That said, there is always the slight possibility that it is the wrong shape.
2013 Smyth Performance G3F - Under Construction!
2014 Smyth Performance Pickup Truck
I try not to own vehicles with less than 200K miles.
The first time I was pulled over I was driving a Peugeot Turbo Diesel. I was 9 years old, and it was 1991.
manual_tranny is online now   Reply With Quote
Old 09-25-2012, 02:45 PM   #100 (permalink)
Cone Killer
RedJoker's Avatar
I was actually thinking more along the lines of shipping damage. (Long story but I didn't actually see it delivered and some parts were bent.) Your FB pic this morning should help as well. Since I got the one side to slide all the way forward, I'll keep fussing and, worse case, follow Marks suggestion of just smacking it with a hammer.
By the way, thank you for checking in on us over here. It's good to see a Smyth representative every now and then. Have a great quarter at school.
RedJoker
Old 09-27-2012, 01:53 AM   #101 (permalink)
Cone Killer
RedJoker's Avatar
Turns out I'm an idiot. My cuts were all good and the frame was fine but it just wouldn't slide forward on the passenger side even with some 'persuation'. Once I lifted that side up and out, I could drop it back in at the correct position. Must be such a tight fit that it wouldn't slide like the other side did. Drilled a hole in the shock tower for the bottom tabs and was able to use the bolt to pull it all in tight.
Good to go!
A side note, that is one BEEFY frame. As John showed in one of his pics, it will support an adult hanging from the top. I won't have to remind folks not to pull themselves out of the car by the windsheild.
RedJoker
Old 09-27-2012, 03:24 PM   #102 (permalink)
Awesome! I'm glad it finally dropped in! You're not an idiot, Mark and I need to come up with better instructions for getting that tough guy installed.
The front frame is usually a two person job around here. It's pretty easy to pinch/cut a finger when they go in if your assistant gets a little too enthusiastic!
I believe that one future revision will actually provide a bolt-on piece going from the top of the windshield frame to the rear frame, providing a race-car like stiffness and some protection for roll-over.
Good to go!
Old 12-18-2012, 09:22 PM   #103 (permalink)
Cone Killer
RedJoker's Avatar
Just another reminder today that 90% of building a car seems to be simply building brackets. Brackets, brackets, brackets....
RedJoker
Old 12-20-2012, 08:00 PM   #104 (permalink)
Cone Killer
RedJoker's Avatar
Forgot to mention that I have another blog update. Nothing much but it's better than I have been doing lately.
RedJoker
Old 01-21-2013, 11:52 PM   #105 (permalink)
Cone Killer
RedJoker's Avatar
An update on the fuel gauge circuit: It didn't work. Turns out the signal from the gauge pod wasn't quite what I expect it to be. New parts are on the way so I hope I can built a better circuit this weekend.
RedJoker
Old 01-21-2013, 11:55 PM   #106 (permalink)
Starship Trooper
Bill Shaw's Avatar
Clint - tell me about the circuit you're designing. I'm in embedded controls so I can probably follow along :-)
Old 01-22-2013, 12:08 AM   #107 (permalink)
Cone Killer
RedJoker's Avatar
It just converts the 0-90 ohm resistance of the new fuel sender to a 50-300 ohm resistance that the gauge is expecting. Since this is going to be my daily driver, I want the gauge to work!
RedJoker
Old 01-22-2013, 12:51 PM   #108 (permalink)
Starship Trooper
Bill Shaw's Avatar
I couldn't agree more, gotta have a gas gauge. The offset is easy, how are you implementing the scaling?
Old 01-22-2013, 03:46 PM   #109 (permalink)
Cone Killer
RedJoker's Avatar
First of all, I'm using a cheap microcontroller to read the new sending unit. That's the easy part. Figuring out what to do next is the hard part.
My first attempt was controlling a darlington array that turned on and off various resistors in parallel to get ~32 resistance steps. My mistake was that I expected the voltage coming from the gauge to be much higher than it is. At only a few tenths of a volt, it couldn't overcome the transistors. My next attempt is that, since the voltage is so low, the current might be down in the range that a digital pot can handle.
If none of that ends up working, I can always just fall back to throwing a resistor in line to get the offset but without the scaling.
Unfortunately, I started this project after my car was disassembled so I couldn't do the measurements until now.
Do you have any ideas / suggestions?
RedJoker
Old 01-22-2013, 05:32 PM   #110 (permalink)
Starship Trooper
Bill Shaw's Avatar
That's funny - I almost added to the previous post - "If I was doing it I'd probably do it with a micro and a digital pot, but that seems like hitting a fly with a sledgehammer :-)" but I got distracted and just hit send.
I used the AD5162 in a Corvette throttle pedal project - range isn't quite right for this but there are other similar parts.
MSOP packages are fun to prototype with :-)
Old 01-22-2013, 05:39 PM   #111 (permalink)
Cone Killer
RedJoker's Avatar
Actually, if you put both 10k pots in parallel, you can control them separately to get at least 32 steps in the range that we need for this. Plus, the current gets split so we get closer to the range they can operate at without smoking. I figure having 32 "positions" in my fuel gauge is plenty good enough.
Great minds think alike!
RedJoker
Old 01-23-2013, 03:17 PM   #112 (permalink)
bzeien's Avatar
A working fuel gauge is a must!
I believe the VW sender is 50 Ohms at full and 350 empty (RCI is 90 full and 0 empty). I was thinking about either reversing the RCI resistance unit and adding discrete resistors to match the gauge, or replacing the RCI resistance unit with the original one from my VW sender.
I'll have them apart on the bench later this week...
bzeien is online now   Reply With Quote
Old 01-23-2013, 05:04 PM   #113 (permalink)
Cone Killer
RedJoker's Avatar
Yup, we're on the same page. I haven't come up with a simple way to use the stock sender but hopefully you can.
RedJoker
Old 01-24-2013, 12:09 PM   #114 (permalink)
Starship Trooper
Bill Shaw's Avatar
50 + 1/(1/340 + 1/2500) = 349.2
A 340 ohm in parallel with the 2500 ohm digital pot should get you real close if I did the math correctly.
Old 01-29-2013, 12:14 AM   #115 (permalink)
Cone Killer
RedJoker's Avatar
Just a quick update, the digital pots work and didn't smoke on the breadboard. Woohoo!!
RedJoker
Old 01-29-2013, 12:49 AM   #116 (permalink)
Starship Trooper
Bill Shaw's Avatar
10k or 2.5k pots?
Old 01-29-2013, 11:47 AM   #117 (permalink)
Cone Killer
RedJoker's Avatar
10k or 2.5k pots?
Dual 10k. As a quick test, I just had them cycle the 32 steps from 50 to 300 ohms and the gauge swept up and down nicely. The damping circuit is in the gauge so we don't have to worry about that part. I'll etch a board and tidy it all up for installation.
RedJoker
Old 01-30-2013, 12:04 AM   #118 (permalink)
Rock on!
Old 02-04-2013, 12:02 PM   #119 (permalink)
Cone Killer
RedJoker's Avatar
urgh... so close to a first start attempt. I was looking at my to-do before I make my first start attempt and the list is really pretty short.
* I have to do something with the power steering pump hoses to loop them back on themselves.
* Plug some vacuum lines that are no longer being used.
* Tidy a bit of wiring in the front.
* Add coolant
Then I can turn the key and trouble-shoot all the reasons why it won't start.
RedJoker
Old 02-04-2013, 03:39 PM   #120 (permalink)
* Add coolant
Mark is with his mother before she goes in for a minor surgery today, so I can't get ahold of him. Looking at our G3F I see that there is no such loop installed, we have been driving it with no loop/fluid!! (stranger still it feels fine) I don't know how this came to be, but I'm fixing the problem immediately. I will post up the parts on McMaster when I know for sure what fits. I will make sure that we send out steering rack loop kits for our beta customers as soon as we know what works. (The parts are probably in a box around here somewhere...)
-Mike
EDIT: Also, I found a link to what the finished loop *should* look like (on a MKII VW)
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
