FFCars.com : Factory Five Racing Discussion Forum - View Single Post - Help!!! Rear Lower Control Arms
Old 10-19-2006, 12:01 AM   #1 (permalink)
syahr
New Member
I’m installing a set of rear ffr control arms on a conventional 4 link suspension. I bought the control arms off this forum used, and do not have any instructions. I have a couple of questions. There are two sets of holes in the bracket on the rear end that the control arm mounts to. Do I use the upper or lower set of holes? The control arms came with the mounting bolts and washers. Do the washers go between the bolt head/nut and bracket or between the bracket and the control arm? Is there a right and left control arm? Or are they interchangeable?
Delivered 8/19/05 MKIII...1990 LX Donner...New 302 long Block...New T5 Transmission...Fuel injected...Factory 5 Control arms Front and Back
syahr is offline
