Damplifier Pro Questions - FFCars.com : Factory Five Racing Discussion Forum
Upholstery & Insulation Forum Sponsored by Second Skin
Phone: (800) 679-8511 or visit www.SecondSkinAudio.com
Go Back   FFCars.com : Factory Five Racing Discussion Forum > General Topics > Upholstery & Insulation Forum Sponsored by Second Skin
Old 09-14-2009, 07:54 PM   #1 (permalink)
JohnnyAvoca's Avatar
To whomever has gone this route;
I would like to get the cockpit covered including all panels, footboxes, floors, doors, rear cockpit wall, trans tunnel, etc. I don't need the trunk done yet.
I would like to go with the Damplifier Pro shop pac with 80 sq. ft. I believe this will be enough for at lease one layer, hopefully more in certain areas.
My questions are;
1. Do I need to get the foil insullation tape to go over the seams or should I just overlap?
2. I want this mostly for heat barrier, but I do have been looking at the strictly heat barriers and I would feel more comfortable using this product and then adding more heat barrier later if needed, hopefully not. Is this the product that I want? I only want to put down one product and then the carpet and I like the idea that this product has an adhesive back.
3. Are there any special tools required to apply this product?
If you have any tips or trick I would greatly appreciate it.
Thanks in advance for any and all opinions.
JohnnyAvoca is offline   Reply With Quote
Old 09-14-2009, 08:07 PM   #2 (permalink)
nickm1024's Avatar
I believe I used 75 sq ft and did cockpit and trunk but I wasted very little. I used regular foil tape you can buy at the hardware store. It don't have to be pretty as it is just going to get covered up!
Posted via Mobile Device
nickm1024 is offline   Reply With Quote
Old 09-14-2009, 10:14 PM   #3 (permalink)
SR71's Avatar
John.... here's my experiences....I think I was one of the first to use this product - as I recall, the "as received" material sizes (Length & Width) have changed since I installed mine.
http://www.legacygarage.com/noise_control.htm
http://www.legacygarage.com/heat_control.htm
Good Luck
Regards
Kevin
My Cobra Website:
SR71 is offline   Reply With Quote
Old 09-14-2009, 10:43 PM   #4 (permalink)
Arch F's Avatar
John,
I am just getting started on this stuff so I am far from an expert, however one tip -
This stuff is very very sticky. Once you put it down, it isn't going anywhere. So, in the more complex or hard to reach areas (footbox, etc.) cut the pieces small enough to place without having to slide them in. I have started pealing just about an inch of the paoer backing and placing the edge where I want it. Then I peal the paper out from under and press the damplifier pro into place as I go.
I like that it comes in flat sheets. It is smooth, not wrinkled like the type that comes in a roll.
Good luck,
Arch
Graduation POM 3000 Mile Trip
3500 Mile Trip
Arch F is offline   Reply With Quote
Old 09-15-2009, 12:34 AM   #5 (permalink)
nickm1024's Avatar
Originally Posted by Arch F View Post
John,
Good luck,
Arch
Good point Arch-
I forgot about that. I tried to use as many full sheets as possible but in the tight spots it just turned into a mess. Patchwork pieces in those spots!
Delivered 3/26/08.
Rollin on temp tags and drivin in gelcoat 10/16/08
Painted and on the road 4/4/09
FFR 7501
Dec '12 repowered 408w w/ mass Flo
Old 09-15-2009, 01:12 AM   #6 (permalink)
Ohio C-car Club
STL-Scott's Avatar
I received a small starter pack last fall as part of Ant's product introduction to this forum, and you can review My Write-up Here
Be prepared for lots of little slices on your hands, fingers, and forearms. Ouch! Mine is still exposed and has not moved around.
Scott
MK3.1 #6583RD, Complete Kit - 4.6L DOHC, delivered 5/03/08, Graduation, July 1, 2010
SOLD to new owner 12/9/11
Complete Bodywork Progress Link
My Build Pictures
STL-Scott is offline   Reply With Quote
Old 09-15-2009, 12:31 PM   #7 (permalink)
Guys
Thanks for all your input. I am going to put the order in today. What type gloves do you recomend? Mechanics gloves ok as I already have more blood into this car than oil.
Thanks for your input
Old 09-15-2009, 04:47 PM   #8 (permalink)
Arch F's Avatar
John,
I have some soft leather gardening gloves that seem to work so far. My mechanics gloves have too many thin cloth areas for me to trust them.
Arch
3500 Mile Trip
Old 09-19-2009, 06:10 PM   #9 (permalink)
Glad to see some of the members here stepping up and answering your questions. I am sorry I was not available for the last couple of days.
Many of our customer use the foil insulation tape on the Damplifier Pro but it is not necessary. The tape ahs a very high heat rating and is mostly used to seal the edges of Luxury Liner Pro and heat Wave Pro. IT will work on the Damplifier Pro but is a bit of overkill.
Damplifier Pro has a very thick foil so it will provide heat insulation for sure.
Your best bet to specifically taget heat it to apply a layer of Luxury Liner Pro or Heat Wave Pro on top of the Damplifier Pro. Then use the foil tape to seal the edges and seams.
A razor blade is great!
The wooden hand roller we offer on our site is very helpful too!
Not much more than that for Damplifier Pro.
Hope that helps!
ANT
Second Skin Rep is offline   Reply With Quote
