33's with LS engines - FFCars.com : Factory Five Racing Discussion Forum
Old 08-21-2012, 11:38 PM   #1 (permalink)
I have done a bunch of searching and haven't been able to find what I'm looking for but I was wondering what kind of transmissions are the guys using LS engines using in the HR's?
I am just trying to figure out which direction I want to go as I am planning on buying the engine, transmission, rear end, and wheels before I order my kit in the spring.
Thanks in advance..
bbksv is online now   Reply With Quote
Old 08-22-2012, 01:34 AM   #2 (permalink)
Tko 600
A TKO 600 w/ram hyd release bearing from American Power Train was my choice. If you want more details, send me a PM.
jim copland is offline   Reply With Quote
Old 08-22-2012, 12:55 PM   #3 (permalink)
33custom's Avatar
tko 600 with mcleod hydo.
depending on what power you will be running a t56 might be an option for you. nice 6 speed transmission.
33custom is offline   Reply With Quote
Old 08-22-2012, 06:38 PM   #4 (permalink)
Building 33 HR #432
jonathanch's Avatar
Trans choice
I am using a ls1/4l60e drop out from a 2002 Firebird. Wanted auto overdrive computer control and wanted units to match the PCM.
jonathanch is offline   Reply With Quote
Old 08-23-2012, 12:36 AM   #5 (permalink)
What did you do about the driveshaft? Did you have to do something custom?
Old 08-23-2012, 12:45 AM   #6 (permalink)
Thanks for the replies. I am going to check out American Powertrain. Just trying to figure out all my options to keep costs down..err..wife friendly..
Old 08-23-2012, 02:00 AM   #7 (permalink)
Building 33 HR #432
jonathanch's Avatar
Drive Shaft
I had FF5 delete the driveshaft when I ordered my kit because they did not have one for the LS/4L60E combination. I am going to have Dynotech Engineering make a custom aluminum one when I get farther along in the build. They made the one for my 66 Chevelle and I was very pleased with there produce.
Old 08-23-2012, 11:39 AM   #8 (permalink)
Mike Forte's Avatar
Hi,
I would install the TKO-600 and use an external slave kit on the bellhousing. I'll forward a picture of it shortly.
Mike Forte
Forte's Parts Connection
40 Pearl Street
Framingham, Mass. 01702
mikeforte302@gmail.com
508 875 0016
www.fortesparts.com
Old 08-23-2012, 01:32 PM   #9 (permalink)
Mike Forte's Avatar
Thumbs up Ext slave GM
Hi,
Here's a Chevy version of an external slave kit with a GM TKO.
Mike Forte
40 Pearl Street
508 875 0016
www.fortesparts.com
