#436 Build Pages - Page 2 - FFCars.com : Factory Five Racing Discussion Forum
Old 06-23-2012, 03:15 AM   #31 (permalink)
oldfartracing's Avatar
I'm having trouble uploading pics, but really don't have a good clear photo. I picked a spot near the center of the tank and brazed on a 1/4" NPT steel bung. A straight fitting 5/16" hose to 1/4" NPT to connect it to the filter provided with the car. Keep in mind that I'll be using a carburetor and don't need a return line. I ordered the pieces from Speedway Motors, 6176702 for the bung, 91611048 for the straight fitting, also available is a 90* fitting 5/16 hose to1/4" NPT part #91611054.
Anyone else having trouble uploading pics?
Pic problem fixed ?
oldfartracing is offline   Reply With Quote
Old 06-23-2012, 10:53 PM   #32 (permalink)
Working on getting the body in place.
Old 06-27-2012, 09:41 AM   #33 (permalink)
Wanted to show the completed gas tank filler hook up, how much the hose had to be modified, and the master cylinders clearance.
Old 06-27-2012, 03:23 PM   #34 (permalink)
Erik Hansen- 33Machine
ehansen007's Avatar
Looks good! Did you route your brake lines on the axle and over the pumpkin?
Erik Hansen
Car no. 240
www.thefactoryfiveforum.com
Old 06-27-2012, 11:28 PM   #35 (permalink)
j33ptj's Avatar
Can't believe the quality of the welds on the gas tank,.... sooo bad!!!
Looks like they were done with a splatter gun...
j33ptj is offline   Reply With Quote
Old 06-28-2012, 08:37 AM   #36 (permalink)
Eric, yes brake lines are stock '88 Mustang.
Old 06-28-2012, 01:42 PM   #37 (permalink)
Tom Veale's Avatar
I, too, shortened the aluminum filler neck as you did. Made the cut in the same place.
As a caution, when you fill the tank with it like that, one can't just shove the pump handle in the hole, as it will potentially damage the rubber El. It's not so much a problem for me, but if anyone else is going to fill the tank, make sure you tell them about it.
As an afterthought, it might have been possible to have just cut off about 1/2 lower portion of the aluminum filler neck along the "diameter" facing the direction toward the tank. Then it won't blind part of the hose for venting and surge.
Best regards,
Tom
#007 Street Rod; #2911SP Challenge Racer (Sold, 06/2010)
V.I.R.U.S.
(Very Immature Racers of the United States)
Tom Veale is offline   Reply With Quote
Old 06-28-2012, 11:43 PM   #38 (permalink)
Thanks Tom for the heads up on the filling process. I may still have to relocate the filler cap to the body surface once the top is in place. This is how I located the opening for the bottom door hinge. I couldn't find anything on it in my manual. Its possible that I missed it, old age and poor eyesight.
Old 06-29-2012, 03:39 AM   #39 (permalink)
towman's Avatar
That's a good idea on how to do the hinge I had a lot of trouble doing my doors the manual isn't real clear good tip
towman is offline   Reply With Quote
Old 06-29-2012, 05:20 AM   #40 (permalink)
j33ptj's Avatar
If I read the manual right, you first mark the door openings on the door, with out the body in place, cut these out and then "back mark" them from the inside of the door to the body.
But how would you know that they have mounted correctly unless you can fit them first???
Hope I will remember this trick!!
Old 07-05-2012, 02:51 AM   #41 (permalink)
I believe this is National Work on Your '64 Falcon Week, well it was for me!
Old 07-06-2012, 03:09 AM   #42 (permalink)
Barrel's Avatar
And '65 Aussie Falcons.
You're right Jim. This is my son's daily driver.
Cheers,
Neil
Photobucket
Photobucket
Photobucket
Barrel is offline   Reply With Quote
Old 07-06-2012, 06:41 AM   #43 (permalink)
j33ptj's Avatar
A proper ute, mate!!
Old 07-06-2012, 05:57 PM   #44 (permalink)
Barrel, very nice truck! Mine was a daily driver up until a few years ago. I've owned it since '86, its been very reliable transportation.
Old 07-06-2012, 06:42 PM   #45 (permalink)
ehansen007's Avatar
Guys:
Did you watch the Video? Don't just read the manual. P.S. I like your way too!
http://www.ffcars.com/forums/120-factory-five-33-hot-rod-forum-sponsored-e-t-wheels/271234-installing-doors-5-part-video.html
Erik Hansen
Car no. 240
Old 07-06-2012, 11:32 PM   #46 (permalink)
33 Moderator
geoffav's Avatar
Barrel
I like the old beat up blue Ford hidden in the garage.
Is that like a 40 inch tall Falcon?
Geoff
FFR 33 #037
FFR 33 Google Map Registry
FFR 33 Hot Rod on FACEBOOK
Old 07-07-2012, 09:15 AM   #47 (permalink)
Eric, I have now, great job with the video! It seems I may have reinvented the wheel on the location of the bottom hinge. Your method of locating the latch and striker sure takes the mystery out of that step. Thanks for sharing these videos with us.
Old 07-09-2012, 02:52 PM   #48 (permalink)
I ran into this little problem this am. To quote Johnny Cash, "When we went to put in the bolts all the holes where gone". Sent pics to tech, waiting to hear back. In my opinion I need a mounting bracket to go with the yellow latch or the clear latch to go with this bracket. The holes in this bracket line up with the template for the clear latch.
Old 07-09-2012, 03:07 PM   #49 (permalink)
1fastsedan's Avatar
Interesting. I have the "yellow" latch and my bracket lined up pretty well. I think they're just going to tell you to clearance the plate holes to match the latch.
1fastsedan is offline   Reply With Quote
Old 07-10-2012, 08:40 AM   #50 (permalink)
Tech says I have the old latches, will send a pair of new ones.
Old 07-12-2012, 01:51 PM   #51 (permalink)
Still waiting for the new latches, maybe tomorrow. Kinda' puts door mounting on hold, don't want to drill any more holes in the doors until I have them in hand. Locating the cutouts on the rear of the door seemed easier on the passenger side. Two tries and it seems close. If this thing had four doors I may have become a pro! Now where did I put that deck lid.
Old 07-19-2012, 09:29 AM   #52 (permalink)
Received new latches on Tuesday, took seven days to get from Mass to SC. Definitely not interchangeable, note the difference in the arm where the cables attach. Does this look correct?
Old 07-22-2012, 09:56 AM   #53 (permalink)
Set the top on to determine the mounting points for the roadster windshield. Would like to have the option to change from coupe to roadster. Any precautions on this process? I've aligned the top according to the manual.
Old 07-28-2012, 10:09 AM   #54 (permalink)
After tracing around where the coupe top goes, installed the windshield on that foot print. Have some fitting to do.
Old 07-30-2012, 04:30 PM   #55 (permalink)
ehansen007's Avatar
Here's what I would do Jim,
Check out all the build topics, especially Rumbles. He's got a ton of great tips and I think it would be faster for you to get answers. It seems you're overlapping a bit here as he's already answered a lot of questions you're asking. I basically went into his build thread and copied and pasted his best tips into a word doc and then printed them out and inserted into my manual. Just a thought.
Erik Hansen
Car no. 240
Old 07-31-2012, 09:34 AM   #56 (permalink)
There is a lot going on in this one piece. Went together by the book.
Old 07-31-2012, 12:59 PM   #57 (permalink)
Fan Shroud
You might want to get one of Mike Everson's fan shrouds before you go any further. It is a whole lot easier to install now than after you put grill/radiator in. Food for thought
cjmccall is offline   Reply With Quote
Old 08-02-2012, 10:54 AM   #58 (permalink)
I was unable to install the grille to the chassis, sent pics to Tech, this is the response.
"I talked to Jesper, and he told me a few things about this. By changing the angle of the grill, that will affect how the hood hinge mount contacts the grill mount. You can also trim the top mount, as it is only a alternative headlight mounting position if you are running full fenders. This should do the trick for you."
Modified the bracket as outlined by yellow tape. Was able to get all four bolts into the grille. The grille is pushed all the way forward leaving no movement for adjustment.
Old 08-06-2012, 10:32 AM   #59 (permalink)
This is probably a common site, hood and side panels overhanging the grille by quarter to half inch.
Old 08-06-2012, 02:07 PM   #60 (permalink)
streetbeast's Avatar
It's a lot easyer to trim the panels then to add to them.
streetbeast is offline   Reply With Quote
