ideas for headlight mounting - FFCars.com : Factory Five Racing Discussion Forum
Old 01-29-2012, 11:00 PM   #1 (permalink)
rons customs's Avatar
here is an idea that stangkiller started and we refined to be able to easily remove the engine side panel once the headlights are installed. he had two aluminum plates 1/2 inch thick cut to a u shape then mounted them with the headlight mount holes centered with the support bar to radiator then we cut the engine panel to fit around the u. split the panel as in the photos and glued 2 pieces of aluminum angle on to each half then bolted the two pieces back together this way you can just unbolt the upper panel and slide back and away from the headlight making it possible to remove the sidepanel easily for work needing to be done
rons customs is offline   Reply With Quote
Old 01-29-2012, 11:47 PM   #2 (permalink)
VERY nicely done !!!!
Tim Whittaker is offline   Reply With Quote
Old 06-20-2012, 05:54 PM   #3 (permalink)
Head Light Mounts
Hi - would you consider making up a set of the mount plates for me? And what sort of price would you need to get ?
Harold
hrfarmsia@msn.com is offline   Reply With Quote
