Another version of side panel venting. I haven't abandoned my louvers yet though. I will install the louvers on the hood soon as well. The screen in the teardrops is straight and true, but the tape makes them look larger as well.
I broke my micro router bit before I got all the louvers mounted, but you get the idea. I louvers are mounted flush and reverse. There are two more per side.
The FFR hood doesn't lens itself well to louvers, but it can be done. I didn't want to compromise the structural ribs on the hood inner skin, so the louvers will have to be arranged as the routed out paths show. Being reversed, I think they will look well when painted and will actually make the hood stronger as the inner and outer skins have to be bonded together at the perimeter of the individual louvered panels.
Routing is mostly completed but no bonding has been done yet. The last two louvers on the outer row and the last one in the middle row ( toward the back ) are not set yet. These will not be functional due to not wanting to compromise the inner skin rib. A row will be added down the middle and this row will also not be functional. However, there will be plenty of venting with the ones that are.
I have the louvers available. Please PM me for details.
The louver installation is pretty time consuming. The inner and outer skin on the hood don't make this a simple task. Once the material is removed for the louvers, the hood needs to be reinforced in that area to regain rigidity. Additional glassing has to be done to make them functional.
Maeir Racing makes one almost identical to that. It would make a nice alternative to the traditional. It's glass and would make the install easier as well.
I modified the factory supplied brackets to allow the strut to be flush with the inside of the fender so it didn't show. The final trim and mounting holes need to be done next.
Where can I get the louvers you are using on your hood to vent it out?
They would do wonders on my project.
thanks in advance for your help
MK4
Final mount and trim complete on fenders. This picture also shows how far off the side panels are from left to right. The drivers side panel is 1/2" higher than the left ( both front and rear) with the body level on the frame. I had to set the elevation of the teardrop cutouts in the side panel with my laser level.
I now have two hoods and two sets of side panels to run. The new hood ( and the old, with louvers ) use the "flush" Mini latch system that get rid of all the FFR stuff and is cleaner, doesn't want to hit the grill when opening and gets rid of the cable stuff. It will basically disappear when the hood is painted. My spreader bar will correct the hood width issue at the grill sides. Gaps have not been finalized yet, but will be a close fit as there's no reason for a huge gap since the grill, side panels and nose cone won't move on the body.
I bonded some steel tubes into the cowl for support for the soft top. The windshield frame offer lateral support but reports are that the soft top places tension on the cowl in the longitudinal so the supports are needed. Large area washers were also bonded for the windshield frame bolts.
I made some epoxy platforms for the windshield post bolts as the bolts run vertical and into a curved surface, so the nuts and washers don't sit on a flat surface.
just a quick note to let you know that I read your posts whenever they come out. I have take a much more simplified approach on 33Coyote, but it is inspiring to see your attention to detail as you continue to raise the bar.
Build site www.33coyote.com
Coyote / TKO 600/3.55/Torsen
Wilwood 6 piston, bike fenders
Boyd's Tank, QA1 shocks & Springs
Speedhut gages
Rag top
"Never let physics or common sense get in the way of a good idea"
Glassed in some washers for the rear body mount so the mounting bolt doesn't just go through glass. There was also a space between the body and the frame mounts, so I filled it with washers bonded in as well.
The bottom side of the fuel door was glassed in. You can see what a nice job the s glass does in small areas like this. The box will have a small drain line attached.
Had to grind a "platform" for the light box to sit for the teardrop tail lights. The body glass was close to 7/16" in some spots in this area. Note the seams have been roughed up from the inside. I will add some thin layers of S glass in this are.
Nice. I hate the thought of working on the body but the few things I've done so far went well. It sure helps having guys who post illustrations and how to details. Thanks for keeping us in the loop, I wish more builders shared tips.
