GenIII HEMI build thread - wife calls it Mistress - Page 3 - FFCars.com : Factory Five Racing Discussion Forum
Old 06-16-2012, 12:14 PM   #61 (permalink)
Tom Veale's Avatar
Pedal height adjustment
Note that the pedal height can be adjusted at the Master Cylinder end. If one screws both the front and rear master piston rods in or out the same amount it changes the height of the pedal at the relaxed position. (no change in brake function)
If you have a hydraulic clutch, you can adjust it the same way to get uniform height. I'm not sure of the gas pedal height.
Best regards,
Tom
#007 Street Rod; #2911SP Challenge Racer (Sold, 06/2010)
V.I.R.U.S.
(Very Immature Racers of the United States)
Tom Veale is offline   Reply With Quote
Old 06-16-2012, 12:44 PM   #62 (permalink)
1fastsedan's Avatar
Best regards,
Thanks Tom. Unfortunately, there wasn't enough adjust-ability for the brake pedal height to clear the steering shaft, so we had to cut off the top of the pedal. Then we did the accelerator to match. I have an auto trans, so the clutch pedal will be a dead pedal. Once we're sure everything is working, we'll cut the clutch down to match the other two.
1fastsedan is offline   Reply With Quote
Old 07-01-2012, 04:03 AM   #63 (permalink)
1fastsedan's Avatar
We're making a big push on the 33 this weekend. 5 straight days working on it. We finished the AC plumbing today and we started on the brake lines.
Old 07-01-2012, 04:27 PM   #64 (permalink)
great job
[QUOTE=1fastsedan;2678929]We're making a big push on the 33 this weekend. 5 straight days working on it. We finished the AC plumbing today and we started on the brake lines.
QUOTE]
Adam
Very tidy looking install on the AC lines. Any way you could post a shot under the dash to see how it lands on the unit?
Dale
HR#431
Buck70 is offline   Reply With Quote
Old 07-02-2012, 12:54 AM   #65 (permalink)
1fastsedan's Avatar
Here is the only shot I have of the back of the A/C unit right now.
Old 07-02-2012, 06:16 PM   #66 (permalink)
thanks
[QUOTE=1fastsedan;2679270]Here is the only shot I have of the back of the A/C unit right now.
QUOTE]
Thanks Adam
I'm still looking for the sweet spot to bring the front downbars of my cage through the dash. I really want them tucked behind the windshield post but that is a very tough spot to land under the dash. It's outside the frame, way behind the firewall and RIGHT where the AC hoses make that loop back towards the middle.
I wonder if there is room to push the whole heater box towards the center of the car a couple inches??
Dale
Old 07-02-2012, 06:31 PM   #67 (permalink)
EFI Rules and Carbs Drool
Arrowhead's Avatar
I didn't buy the A/C from FFR, but it's a Vintage Air Gen II mini and the heat and A/C connections are at the bottom - maybe that would work better fro you?
FFR '33 #78
Picked up 5/30/09
Old 07-03-2012, 01:07 PM   #68 (permalink)
good ideas all around
[QUOTE=Arrowhead;2679624]I didn't buy the A/C from FFR, but it's a Vintage Air Gen II mini and the heat and A/C connections are at the bottom - maybe that would work better fro you?
QUOTE]
That looks like a good alternative.
Adam
Sorry for the thread jack, you have so many innovations that are relevant to my build that it always sends me off in another direction. I hope to post some pics eventually on my mods to the 4 link changes I'm making for
better ride height.
DB
Old 07-03-2012, 01:45 PM   #69 (permalink)
1fastsedan's Avatar
No problem Dale, that's what we're all here for.
We finished up the brake plumbing yesterday!
Mounting the body and seats today.
Old 07-03-2012, 05:29 PM   #70 (permalink)
bleed right
Very tidy line job,
I'm leaning towards floor pedals but I need to drive one first to see if
I like the feel.
Another benefit of the floor mounted pedals, it's easy to bleed the system
because the MC's are mounted enough higher to work properly.
DB
Old 07-04-2012, 05:02 AM   #71 (permalink)
1fastsedan's Avatar
We got the body mounted today and the drivers seat with adjustable tracks figured out and mounted. Tomorrow we're hoping to get the passenger seat and both doors on.
Old 07-04-2012, 05:27 AM   #72 (permalink)
j33ptj's Avatar
Is that paddle shifters I see on the steering wheel???
Cool!!
j33ptj is offline   Reply With Quote
Old 07-04-2012, 02:03 PM   #73 (permalink)
1fastsedan's Avatar
Cool!!
Why yes it is. Clean interior was my goal. No center shifter, no visible AC vents, and no visible switches. I have 2 out of those 3 already handled...
Old 07-05-2012, 03:03 AM   #74 (permalink)
1fastsedan's Avatar
Day 5 of the July 4th push was a bitter fight until the very end. We ended up with the passenger door mounted...and mounted well, but it took all day.
Old 07-05-2012, 04:35 PM   #75 (permalink)
What!?
That Hemi is covered with what???!!! Please get that motor a proper blanket!
ksuhre is offline   Reply With Quote
Old 07-05-2012, 05:13 PM   #76 (permalink)
1fastsedan's Avatar
Hahaha, so true. My wife donated it to the cause, so I guess I can't be too picky. Plus, I do love my HEMI, so I guess the hearts are appropriate.
Old 07-08-2012, 03:51 PM   #77 (permalink)
1fastsedan's Avatar
After 2 days of body work, we have achieved roadster-dom! Both doors are on, level, and latching. Got the trunk fitted up yesterday too with 2 pleasant surprises - the curve on mine is right on and there is an aluminum plate bonded in for the rivnuts to grab.
Old 08-06-2012, 01:44 AM   #78 (permalink)
1fastsedan's Avatar
We spent the last 3 weeks finishing up loose ends and finally started to tear everything down for chassis powder coat and to start some finish work. We tore the car down in 3 days. Here is how she sits right now. Off to powder coat tomorrow...
Old 09-11-2012, 02:38 AM   #79 (permalink)
1fastsedan's Avatar
Just a quick update. Everything is almost done at powder coating. Here are the small parts. The chassis should be done this week too. 2-stage misty purple powder on all.
Old 09-11-2012, 03:24 AM   #80 (permalink)
I completely approve of the purple
Neptune's Snorkel is offline   Reply With Quote
Old 09-12-2012, 03:22 AM   #81 (permalink)
1fastsedan's Avatar
They finished up the chassis today. Lots o' purple pipes.
Old 09-25-2012, 12:19 AM   #82 (permalink)
1fastsedan's Avatar
Final assembly of the chassis started yesterday!
Old 10-02-2012, 01:01 AM   #83 (permalink)
1fastsedan's Avatar
Pretty busy day working on the 33 today. Had some successful testing for engine turning the firewall, re-tapped all of the holes in the chassis, got all the aluminum chassis panels primed and undercoated with special blend of bed liner with ceramic microspheres (kind of like a polyurethane version of lizard skin), fuel tank/lines and brake lines were reinstalled, and we got the exhaust re-installed. All while it was 100 degrees out.
Old 10-02-2012, 06:10 AM   #84 (permalink)
Kaelan G's Avatar
Those SRT 300 wheels look great!
-Kaelan G
Kaelan G is online now   Reply With Quote
Old 10-02-2012, 01:19 PM   #85 (permalink)
1fastsedan's Avatar
Thanks! Honestly though, they're the only wheels we had around that would clear the brakes. I'm leaning towards 17 inch fronts and 18 inch rears.
Old 10-02-2012, 03:31 PM   #86 (permalink)
Erik Hansen- 33Machine
ehansen007's Avatar
I think they are awesome too. A great representation of the heart and soul of the 300M Hemi!
Erik Hansen
Car no. 240
www.thefactoryfiveforum.com
Old 10-02-2012, 03:40 PM   #87 (permalink)
Adam can you PM me your phone number so I can call and make arrangements to come down as we discussed previously - got no reply to my last PM for a phone number as of yet. Thanks in advance.
Art / WIREDIET.com
Banner
Art Cuesta is offline   Reply With Quote
Old 10-02-2012, 07:38 PM   #88 (permalink)
1fastsedan's Avatar
Art / WIREDIET.com
Sorry Art, I thought I wrote you back. PM on its way.
Old 10-12-2012, 07:17 PM   #89 (permalink)
BEAUTIFUL!!! Keep the pictures coming!
Garth66 is offline   Reply With Quote
Old 10-12-2012, 10:04 PM   #90 (permalink)
Sema
Adam
Looks like you are on track for SEMA
You have a booth or joining FF at the show?
Dale
