I have finished my Rumbles Build Journal and put it online for all to download. I've collected, edited, and reformatted all my content from this forum into a printable "Rumbles Build Journal.PDF document. Its over 110 pages long and contains 140+ illistrations.
If you are having difficulty seeing the PICs in this forum, you should be able to see them in this PDF document.
Click here to
download the "Rumbles Build Journal.PDF" document
Here's the Table of Contents:
70 Days to Roadworthy
1/23/10 - My Kit is in the mail4
1/24/10 Preparing the Rear-end. 4
1/25/10 Received My Hot Rod Kit Tonight5
1/26/10 (Day 1) Eliminating the AC and PS pumps on a 4.6 DOHC. 7
1/29/10 (Day 4) Inventory is completed. 8
2/7/10 (Day 13) Allot has happened over the past 2 weeks:10
2/8/10 (Day 14) I received 2 deliveries today:11
2/12/10 (Day 18) My frame is back from powder coating.12
2/13/10 (Day 22) Wheels and Tires. 13
2/17/10 (Day 23) Been making some progress on assembling the chassis. 14
2/18/10 (Day 24) It’s Nervous System is Alive!15
2/20/10 (Day 26) The Rapid Flasher problem is fixed!15
2/24/10 (Day 30) The Eagle has landed!16
2/26/10 (Day 32) Firewall is in. 17
2/27/10 (Day 33) The Engine is in. 18
3/5/10 (Day 38) Engine Management System is done. 20
3/7/10 (Day 40) The engine cooling system is done. 22
3/8/10 (Day 41) The exhaust, battery and drive shaft are done. 23
3/9/10 (Day 42) Critical Path ahead. 24
3/10/10 (Day 43) Air Intake System.. 27
3/12/10 (Day 45) Finished the fuel line. 28
3/14/11 (Day 47) The Moment of Truth. 28
3/15/10 (Day 48) I got my Pivot Sleeves. 29
3/29/10 (Day 66) Working My Way Down the Punch list29
3/31/10 (Day 67) Last few items to get it on the road. 34
4/1/10 (Day 68) Doors…Doors…Doors….. 34
4/5/10 (Day 70) Installed the trunk lid, cockpit tin and windshield. 40
It’s Roadworthy!42
Cruising and Tweaking the Details
4/29/10 Alignment problem.. 44
5/23/10 Refining the Door Latch System.. 44
5/25/10 Fuel Tank Venting and the Filler Neck. 45
6/3/10 I Got My Plate. 46
6/22/10 Herky Jerky Speedo. 46
6/24/10 Speedometer Problem Fixed. 47
7/2/10 Interior is complete. 48
7/13/10 Fixed the Front Alignment51
7/14/10 Simple Front Alignment with 4 Common Tools. 51
8/21/10 Hood and side Covers. 54
9/13/10 Hood Stops. 60
9/23/10 Fitting the Hard Top. 62
10/26/10 Final Trim and Mounting the Hard Top. 64
11/26/10 Installing the Power windows. 65
1/22/11 Tips on the Willwood Braking System.. 67
2/19/11 Momma Needs Bling. 68
3/2/11 Battery Tray. 70
5/23/11 Sound Deadening. 71
5/30/11 Final adjustment of outside door handle. 73
5/29/11 Final power window adjustments. 74
6/1/11 Weather stripping the doors. 75
Some Assembly Required….. 80
Bodywork, Paint and Reassembly
The Paint Scheme. 83
Selecting a Body Shop and Painter. 88
3/22/11 Body Work Update. 90
3/27/10 Son of Blob. 91
4/2/11 I See Red!92
4/4/11 The Hard top is done. 94
5/1/11 On the Road Again. 95
5/4/11 Glamour Shots. 96
Appendix
List of additional items you need for the build
Tips for reliable running gear
